What is it? Help needed
angelbabaloo
angelbabaloo is offline
PostPosted: Thu Apr 15, 2021 9:40 am    Post subject: What is it? Help needed Reply with quote
Hello from Greece
we bought this van and it is hard to understand what type is it.
Based on the chase num. is 69 (?) based on actual look front and back looks 79
The chase num is 239085844
Anybody can tell?
Thanks a mill
OB Bus
OB Bus is offline
PostPosted: Thu Apr 15, 2021 9:44 am    Post subject: Re: What is it? Help needed Reply with quote
Well I see a 73-79 nose, a 72?-79 taillights and are those rounded scoops? Then 68-72.
Wheel bolt pattern is the smaller one, so 71-79.
Hybrid?
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
angelbabaloo
PostPosted: Thu Apr 15, 2021 10:19 am    Post subject: Re: What is it? Help needed Reply with quote
Thanks, according to the chase number is supposed to be a 69 right?
Maybe at sometime they changed the nose and the taillights .
Any other thoughts, or a way to check whether it is a pre 73 or not?
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Apr 15, 2021 10:44 am    Post subject: Re: What is it? Help needed Reply with quote
that bus is a total bastard....
nose wrong and dog legs wrong for a early bay. i am betting on a full nose swap. wrong pop top as well.
if you are thinking of buying this, i wouldn't
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
angelbabaloo
PostPosted: Thu Apr 15, 2021 10:52 am    Post subject: Re: What is it? Help needed Reply with quote
we bought it already Sad
based on chase num is type a .... right?
any guess why someone to do all those changes?
just for the history the van is all rusted, (couldn't tell before today Sad
HoboBus
HoboBus is offline
PostPosted: Thu Apr 15, 2021 12:01 pm    Post subject: Re: What is it? Help needed Reply with quote
The taillight LENSES are later, but the CORNERS are not. Look closely.
The lenses are closer together, and the corner of the metal doesn't have the bulge.
Weird.
Salt air it ain't thin, it'll stick right to your skin,
it'll make you feel fine. Makes you feel fine.
And I wanna be there. -- Jimmy Buffett
Just a beach-oriented camping Hobo with a bus.
Wildthings
Wildthings is offline
PostPosted: Thu Apr 15, 2021 12:02 pm    Post subject: Re: What is it? Help needed Reply with quote
For the international market VW just cobbed all kinds of stuff together, so very likely a factory '79 model.
What engine does it have? Type 1 or Type 4? I don't think much of cutting a hole in the engine room door, great way to suck in hot engine air and combined with dust kicked up by the tires.
alman72
alman72 is offline
PostPosted: Thu Apr 15, 2021 1:23 pm    Post subject: Re: What is it? Help needed Reply with quote
more evidence for late in OPs pics. turn signals are late vs early
angelbabaloo
PostPosted: Fri Apr 16, 2021 1:01 am    Post subject: Re: What is it? Help needed Reply with quote
unfortunately the engine has been changed so no idea what it was.
The chase num are 9 digits.
It suppose to be before 1971
JaimeH Premium Member
JaimeH is offline
PostPosted: Fri Apr 16, 2021 4:20 am    Post subject: Re: What is it? Help needed Reply with quote
That's right. If it were a '79 VIN the number would be 239 2 085844
1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH
Rider_Surfboards
Rider_Surfboards is offline
PostPosted: Fri Apr 16, 2021 6:02 am    Post subject: Re: What is it? Help needed Reply with quote
My best guess is the VIN number indicates the correct year. You definitely have an early Bay rear based on the rounded corners, half moon air scoops, etc. Also it is lacking the flare at the tail lights as seen on this late Bay, which indicates someone most likely attached the late bay lens.
*That bus is most likely a 72 based on the bumper, but that’s irrelevant to this discussion.
The front of your bus, aside from the high turn signals, also has the late Bay bumper support, which is interesting. As previously stated, most likely the entire nose was swapped at some point.
To confuse things even further, it appears you have a late bay Westfalia top, which started in 1974, if I recall correctly, but that could have been added after the fact as well.
Don’t be bummed about your purchase. Embrace the frankenbus and enjoy the process of restoring it to whatever you want. Make it yours and have fun!
— Kevin
1979 Bus Weekender -- Gertrude McBus
Wildthings
PostPosted: Fri Apr 16, 2021 8:39 am    Post subject: Re: What is it? Help needed Reply with quote
A picture of the right side showing the fuel filler area would be informative.
