buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Sat Apr 17, 2021 2:45 am Post subject: Re: Won't pull past 6000 |
Plx is good I have one also. But no recording options at all. Just a gauge. When you can look at a graph and see exactly what the car is doing for the entire drive instead of trying to watch it and drive. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Apr 17, 2021 3:56 am Post subject: Re: Won't pull past 6000 |
what size exhaust Header? what goes in must come out , seen this happen with 1 5/8" _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 418 Location: Nowhere, USA
Posted: Sat Apr 17, 2021 4:58 am Post subject: Re: Won't pull past 6000 |
vwracerdave wrote: |
Make sure when you press the gas pedal the carbs are opening up all the way. The pedal could be limiting the carbs. |
My money is on this. _________________ Stan Galat
"Everybody is entitled to their own opinions, but not their own facts." |
dwightly Samba Member
Posted: Sat Apr 17, 2021 6:14 am Post subject: Re: Won't pull past 6000 |
Hello Mike. The headers are 1 3/4" . I believe I bought it from you several years back.. I will check throttle wot when I get home.in a couple of days. |
Posted: Sat Apr 17, 2021 9:37 am Post subject: Re: Won't pull past 6000 |
my pulling issue was 100% bad valve springs, they can go bad fast if your floating the valves... Or if they are set up wrong _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
Posted: Sat Apr 17, 2021 9:49 am Post subject: Re: Won't pull past 6000 |
Tims set them up .I double checked them. About a 1000 mi. on them. |
mark tucker Samba Member
Posted: Sat Apr 17, 2021 10:13 am Post subject: Re: Won't pull past 6000 |
exhaust/muffler, air filters,fuel return returing tomuch,what do the plugs look like on a clean cut run?low voltage to the coil,throttell opening,cam off a tooth or 2.....if it's valve float you should be able to hear that....well some can and some cant. dead/dying coil wire...sealed engine compartment making the carbs&fan compeate for air...tach on the rong setting |
74 Thing Samba Member
Posted: Sat Apr 17, 2021 10:25 am Post subject: Re: Won't pull past 6000 |
Post a photo |
Posted: Sat Apr 17, 2021 11:17 am Post subject: Re: Won't pull past 6000 |
Mark, I'm suspecting coil supply voltage and or tach wiring cuz my tack is erratic.was going to run direct wire from alt batt pos to coil positive first.if that doest work i will disconnect tach from coil.hopefully that's the problem |
Posted: Sat Apr 17, 2021 11:40 am Post subject: Re: Won't pull past 6000 |
How does valve float sound like ? |
Posted: Sat Apr 17, 2021 12:31 pm Post subject: Re: Won't pull past 6000 |
Instead of pulling it will lay over and the engine pitch will change. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
Posted: Sat Apr 17, 2021 12:52 pm Post subject: Re: Won't pull past 6000 |
Like a lower pitch ? |
Posted: Sat Apr 17, 2021 12:54 pm Post subject: Re: Won't pull past 6000 |
Lower or level out kinda. Drive a stock bug and don’t shift. At 4K or a little above the valves will float. Sounds like that.
Or you stop feeling it pull using your butt Dyno. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
Posted: Sat Apr 17, 2021 1:07 pm Post subject: Re: Won't pull past 6000 |
When it does it ,it sounds like it choking or gasping for air kinda.i know its actually not an air restriction problem(stand off lid,no air filters or stack screens).hard to believe its valve float with properly set up new cb650 springs tho. |
Posted: Sat Apr 17, 2021 5:57 pm Post subject: Re: Won't pull past 6000 |
Get out your multimeter and check out the ignition. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sat Apr 17, 2021 6:49 pm Post subject: Re: Won't pull past 6000 |
If you keep flooring it at the 6000 mark what does it do? Does it want to just die out? Does the firing get erratic or does it full on stumble like poor mixture?
Could it be a bad ECU or coil that isn't able to handle the RPM? _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Posted: Sat Apr 17, 2021 6:58 pm Post subject: Re: Won't pull past 6000 |
Boggs down.like its runs out of fuel.lower sounding engine tone |
nsracing Samba Member
Posted: Sun Apr 18, 2021 4:20 am Post subject: Re: Won't pull past 6000 |
18-degrees of initial timing? why so advanced on idle? That may be your problem there.
and what size venturis? |
Bill Schwimmer Samba Member
Posted: Sun Apr 18, 2021 5:58 am Post subject: Re: Won't pull past 6000 |
The oval gas cap is not vented enough. I have run into this before. Try a little run with the cap off. If it still does it. Look elsewhere, but the tank still needs to be vented. |
