BFB Samba Member
Posted: Sat Apr 17, 2021 7:15 am Post subject: porting s.p. heads? |
any of ya'll ever do any porting and flow testing on single port heads? what was results?
one, im just curious and two, i got a buddy building a rat rod type vw and thinking about dual carbing a single port. i picture a retro 60's look with some long runners and tall velocity stacks, maybe not what he's planning but i think it'd look cool.
i know single ports aren't the popular choice ( which is another reason i like the idea ) but i remember seeing a few threads where stock s.p. was compared to stock d.p. and there wasn't much difference? _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" - bdkw1 |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Sat Apr 17, 2021 7:50 am Post subject: Re: porting s.p. heads? |
back in the '80's I ported a set of SP and ran a 34 pict3 (cut off the flange from a DP manifold and welded on to a SP manifold)
1600 SP w/stock cam and sig erson 1.5's
ran mid/low 17's in the 1/4 with a full body stock trans
you can get more from a DP, but sometimes it fun just seeing what you make out of scrap parts... |
mark tucker Samba Member
Posted: Sat Apr 17, 2021 9:34 am Post subject: Re: porting s.p. heads? |
if you know what your doing yes they should work good, you can do a lot as with most heads.the better you are and the more equipment you have to do it with the more power you could see...if you know what your doing.and just want to. |
74 Thing Samba Member
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sat Apr 17, 2021 11:20 am Post subject: Re: porting s.p. heads? |
THAT.
1776 sgl port w. W100 cam, 1,25 rockers on intake, 4-1 header w dual mufflers and modded dual 34 mm Solex.
I have actually been experimenting with a 90,5 x 80 (2060cc) for an early 60īs split bus, using 40 Kadrons as induction and a camouflaged Vintage speed type muffler for stealth look. The first 110 hp are reasonably easyl to find without sacrificing nice and clean idle, which is a must in this case. But after that it gets difficult. 120 hp is reasonably easy to find, but at the cost of a lopey idle. One of the eye openers was that there was almost no performance gain with a 39 mm intake valve over a 37,5 mm valve eventhough the 39 mm valved flowed better in the bench. Something happens with the reversion around there. So far I have not found out what or where. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sat Apr 17, 2021 11:30 am Post subject: Re: porting s.p. heads? |
I think he's not porting anymore, except for his own builds. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Sat Apr 17, 2021 1:25 pm Post subject: Re: porting s.p. heads? |
I have only done a little with SP heads but what little I did worked nicely.
IMO achieving more flow though the port is only one piece of the puzzle, and only worth focusing on once all else is figured out and proportioned right.
the choice of cam, valve size, and seat angles is a slightly tricky thing because one runner feeds two valves.....the amount of overlap between those valves is important. Has to be enough, so so the runner can transition from feeding one to feeding the other with minimal interruption, but not too much. Too much then the intake flow during that period takes the path of least resistance instead of it going where you want it to go.
37mm valve is a fine size for the largest intake manifold it is possible to normally fit on the head. fitting a larger intake manifold might be as simple as boring the pocket larger, but I haven't done that yet. |
Posted: Sat Apr 17, 2021 2:07 pm Post subject: Re: porting s.p. heads? |
modok wrote: |
Thatīs what I did because the same procedure have worked very well on 30 hp (36 us) engines with more bore and up to 35 mm intake valves. But for some reason at least this set of heads did not like it much. Changes in exhaust and exhaust valve lift didnīt cast any light over why.4
This is a slow project. I only work on it once in a while. When spring is over I might take it off the shelf again. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
modok Samba Member
Posted: Sat Apr 17, 2021 5:07 pm Post subject: Re: porting s.p. heads? |
Of course.
If there is not enough room on the seat insert for what I feel are the correct angles, I consider that a problem, and find a way to fix it. |
spencerfvee Samba Member
Posted: Sun Apr 18, 2021 4:27 am Post subject: Re: porting s.p. heads? |
Alstrup wrote: |
THAT.
I have actually been experimenting with a 90,5 x 80 (2060cc) for an early 60īs split bus, using 40 Kadrons as induction and a camouflaged Vintage speed type muffler for stealth look. The first 110 hp are reasonably easyl to find without sacrificing nice and clean idle, which is a must in this case. But after that it gets difficult. 120 hp is reasonably easy to find, but at the cost of a lopey idle. One of the eye openers was that there was almost no performance gain with a 39 mm intake valve over a 37,5 mm valve eventhough the 39 mm valved flowed better in the bench. Something happens with the reversion around there. So far I have not found out what or where. |
..................................................................................................................alstrup what year single port heads do you think were the best heads to port ?. . my self i like the 1968 to 1970s single port heads .i have had the best luck with the 1970s single port heads . take care spencerfvee |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Sun Apr 18, 2021 6:07 am Post subject: Re: porting s.p. heads? |
I have posted these elsewhere before, but here they are again. I did them a long time ago, and they worked pretty good. Decent amount of work, but the engine drove pretty nice. I filled the copper sealing ring groove, and then made it larger diameter. I moved the mounting studs out, and made them 8mm. Then I made new tapered Kadron manifolds with the larger ID at the bottom flange. The engine was a 1915cc, stock crank, these heads, Web 218/119, 8.5, and a 1 3/8" header. Next time I would stick to a 1776, or 1835, and use a smaller cam. No more than 238deg @ .050".
In the end, they flowed about the same as a warmed up dual port head with the same size valves.
I still have the heads and manifolds, and I keep thinking I should rework them a bit and build another engine for them. A 37mm intake valve would most likely help. I have learned a lot about seat angles and valve jobs since these were done 8 years ago, and I know they can be made better now.
I have built a lot of quick easy single port heads since then, and following the link 74thing posted is the best thing to do for most guys. The valve job is VERY important, and the easiest way to see the biggest gains. A very simple 1776, 8.5, dolled up heads just like the other link I did, a cb2232 cam, kads and a header make for a great little engine. Easy to build, easy to drive, and relatively cheap to build.
Racerdave and Roy will be along shorty to tell us all how single port heads are a complete waste of time........😂😂😂😂🤦🏼♂️
Brian _________________ www.type-emotorsports.com |
Posted: Sun Apr 18, 2021 8:18 am Post subject: Re: porting s.p. heads? |
Hehe.
Wrt cam. I agree as such. It is VERY easy to overcam a sgl port. That said I have used up to 10 degrees split on some sgl ports. I built a 1914 several years ago (the only sgl port 1914 I have ever built, and will not build 94 mm bore sgl ports again for several reasons) That was for a split bus and on custumers reques.t Ended up with 6 degrees split, 0,010" difference in valve lift, and 110 LC
- Actually, in slightly larger than stock displacement sgl port engines w. dual carbs the Engle W100 cam works quite well. Also, in the same range, even stock carbed sgl ports controlled by a W90 works surprisingly well, - as long as you are not affraid of compression. - Not my favourite, but it deserves to be menthioned. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Sun Apr 18, 2021 9:25 am Post subject: Re: porting s.p. heads? |
I think many single port intakes are too restrictive.duels&singles, you can over carb a intake&under carb the same engine.... personaly If I were to do a single port I would split the ports,make each bigger run a devider in the intake so it would now be a duel port...in single port clothes. if the fireing order was different the stock system would run beter with more cam.but it aint so it is what it is.( making a bigger single port looking manifold into a duel wouldn't be that hard to do.) or just stay with the single stuff and have a lopey idle...witch is what most want any way. |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
Posted: Mon Apr 19, 2021 2:51 pm Post subject: Re: porting s.p. heads? |
mark tucker wrote: |
You are correct.
If you look at flow numbers alone it is pretty much like Brian also menthions in his sgl port thread, that the first 120 cfm @ 25" and 0,500" lift are pretty easy to get. The 37,5 intakes that I have done flowed 142 cfm @ 0,530" and the 39 made 145 cfm at 0,540" what was odd was that the 39 mm valve did not improve performance one bit even though the carb/ manifold flow potential was present. I did not work more with it at the time, but some day I will research it again and find the issue. We also have more hardware to test today than we did back then. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
BFB Samba Member
Posted: Mon Apr 19, 2021 4:39 pm Post subject: Re: porting s.p. heads? |
Alstrup wrote: |
You are correct.
If you look at flow numbers alone it is pretty much like Brian also menthions in his sgl port thread, that the first 120 cfm @ 25" and 0,500" lift are pretty easy to get. The 37,5 intakes that I have done flowed 142 cfm @ 0,530" and the 39 made 145 cfm at 0,540" what was odd was that the 39 mm valve did not improve performance one bit even though the carb/ manifold flow potential was present. I did not work more with it at the time, but some day I will research it again and find the issue. We also have more hardware to test today than we did back then. |
id need to go look a s.p. head again, but without looking.. what if instead of dividing the ports you hogged out the intake chamber to be one big chamber? could the small diameter of the intake increase the air / fuel velocity to the larger chamber to feed the intakes and get any benefits? i dont know what the hell im talking about, just jabbering goofy ideas.
also, yall talked about overlap hurting s.p. flow? would a s.p. benefit from a cam with a wider lsa then? _________________ Forced induction can overcome a lot of obsticles that gets in it's way
Posted: Mon Apr 19, 2021 5:19 pm Post subject: Re: porting s.p. heads? |
richardcraineum wrote: |
No. You need a certain amount of port to direct the flow into the valve seat, - and chamber.
ABSOLLUTELY! As I wrote earlier, split duration, split lift and wider lobe separation all helps.
Not that I would recommend this, because there is much more to it than just cam overlap. But just for you to get an idea about it.
We take a regular W100 cam. It has approx 20 degrees overlap at tdc.
Then we can take another shelf cam, the TSC 10 It is 247/236 @ 0,050" and 112 LC. This cam has only 17 degrees overlap at tdc, - so theoreticly this cam would idle BETTER than the milder W100 on a regular 108 lc.
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Tue Apr 20, 2021 2:36 am Post subject: Re: porting s.p. heads? |
I remember some formula-V heads I once saw, the port volume was hogged out to become one big bowl, and the intake was welded up for a four-bolt flange to clamp the manifold onto. They were flycut like crazy, and were just one big crack. |
Posted: Tue Apr 20, 2021 7:58 am Post subject: Re: porting s.p. heads? |
with bigger valves always make sure the chamber is un shrouded. chamber shapes affect flow a lot more than most people think on intake and exhaust. most people dont have a clue what a port needs to flow better and just do some pretty look at what I did work....kinda like fake boobs..did the fake boobs for the real issues??probably not.
also....many people dont realize the chamber shape starts at the 45 degree seat. and that aera and the next 3/8-3/4" outward is very important to flow. just look at how flow increases as the chamber is milled. ad to that a proper shaped chamber and you have the start of a good head,untill know it all joe bubba type exspurt car club president machinist with his fully equipped machine shop( die grinder)gets a hold of it....in the dirt ..on the dirt floor of his shed trying to make some $$ so he can send his car to somebody to get it to start and fix all the effed up stuff. |
