donny273 Samba Member
Joined: September 08, 2004 Posts: 50 Location: Massachusetts
Posted: Sat Apr 17, 2021 9:49 am Post subject: Moto meter gas gauge |
Does anyone know a source for a sending unit that will work with a 6 volt moto meter gas gauge? Oil pressure as well. Thank you |
Bub Samba Member
Joined: June 10, 2004 Posts: 1154 Location: Central Washington
Posted: Tue Apr 20, 2021 8:47 am Post subject: Re: Moto meter gas gauge |
You results may vary- but when my Motometer fuel gauge was working this VDO sender DID work with it --> https://www.amazon.com/gp/product/B000NBE5Z2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1<---. It doesn't seem to have the low fuel warning circuit for the light that took the place of the AMP meter part of the 3-in-1 gauge.
I have found that these OLD gauges do seem to have been fine-tuned/ paired with senders when they were new. Either that or the specs are just trashed from being sold old. You'll find one gauge works decent with a 10-90ohm range and another will need like 40-170 range. So you may have to tweak things, add a resistor in the line or something.
Nice thing about that sender though is that you can mount it in the filler neck and its very height adjustable.
For the temp sender...good luck. I haven't found anywhere that sells one outright that I think works. Best way to use your old gauge - that I know of- is to get a little decade box setup and calculate the resistance that it operates within then find a thermistor / sensor that works in the same range.
I had it figured out for my 3-in-1 gauge but the gauge itself is so unreliable that it really doesn't show any reliable reading. One day 'warm' reads normal on the gauge and the day a 'warm' engine will peg the gauge. Or maybe it wont work at all.
Took me a month of work to get it working decent then the 2nd day the fuel gauge read funny and I tapped on the gauge and it just totally died. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Wed Apr 21, 2021 5:17 am Post subject: Re: Moto meter gas gauge |
Great information. Thank you so very much. |
