83.5 1.9L crank no start after dash removal
Cornell89
Cornell89 is offline
PostPosted: Sat Apr 17, 2021 9:53 am    Post subject: 83.5 1.9L crank no start after dash removal Reply with quote
I picked up a new project van about a month ago - an 83.5 Westy w/ 1.9L. Over the past month it's always started easily on the 1st try and ran well. This week I started tearing it down for a complete respray and interior refurb.
After I removed the dashboard (but plugged the instrument cluster back in), the starter still cranks strong but the van won't start.
Here's what I've checked so far:
- checked for loose or shorted wires around the dash (in case I knocked something loose while removing the dash) and checked all fuses
- checked the ignition switch (I have a spare)
- checked and cleaned ground wires (engine & transmission ground wires and main battery ground cable)
- checked for fuel problems - normal start-up whine from fuel pump, cracked open the bleeder to confirm fuel flow, and removed injectors to confirm they are firing
- followed this diagnostic procedure to check for spark and check the hall sensor connector - https://www.youtube.com/watch?v=95PkgSavOCo
I've got spark and I've got fuel - what am I missing?
jlrftype7
jlrftype7 is offline
PostPosted: Sat Apr 17, 2021 1:38 pm    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Check for a loose or blown fuse in case something happened during Dash Removal- other than that, loose connection at ignition switch connector, like a pin that spread open a bit and isn’t making contact again once plugged in.
I’m a bit stumped too since you say you have fuel and spark , and removing the dash didn’t kill those two things . Will be interesting to hear what it was.
I had zero issues with my Dash removal to rebuild the heater box and other things last Feb., but there are dangling wires and connections that could go wrong for sure. .... Crying or Very sad Crying or Very sad
‘84 Tin Top - Hilga....Auto
16CVs Premium Member
16CVs is offline
PostPosted: Sat Apr 17, 2021 1:55 pm    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Do you have a tachometer, Is it jumping? Do you hear the fuel pump cycle when you turn the key on?
Stacy
Samba member # 14980
MarkWard
MarkWard is offline
PostPosted: Sat Apr 17, 2021 4:30 pm    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
It might be coincidence.
Cornell89
PostPosted: Sun Apr 18, 2021 10:21 am    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Already checked, and for the hell of it checked again - I even continuity tested all of the fuses - no problems found.
When I did my initial check for spark and injector spray I only check the driver's side. I went back this morning and checked the passenger side - good spark and injectors firing.
I've already check ground wires, but this reminds me of problem with an old tin top that turned out to be a bad negative battery cable - in that case, the terminal wasn't attached correctly. The battery cable on the current van appears to be original and is covered in electrical tape, and it was bent and twisted when I disconnected the negative terminal when removing the dash.
Cornell89
PostPosted: Sun Apr 18, 2021 1:20 pm    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
No tach in the early 1.9L vans.
As for the fuel pump:
I've also done a cold compression test - ~115 on #1, all others ~120. Not spectacular, but I don't think it's bad enough to prevent the van from starting.
brickster
brickster is offline
PostPosted: Mon Apr 19, 2021 7:37 am    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Have you attached a gauge to the fuel port? It would be good to know the actual pressure (vacuum line connected, then unconnected a la Bentley).
Is the spark you saw a bright, white spark?
Known good battery (load tested)?
Cap, rotor & plugs in known good condition?
You seem to know what you're doing, just wanted to throw some other thoughts out there.
MarkWard
MarkWard is offline
PostPosted: Mon Apr 19, 2021 8:00 am    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Look at the factory manual page 97.55 and 97.56. Specifically wire connectors T2a and T2b. They go from the ignition switch starter solenoid circuit to the vans ECU pin 21. Both are indicated connectors behind the dashboard. If you unplug the ECU and crank the engine, you should have battery voltage at pin 21 of the ECU plug. If you do, you have eliminated the two T2 connectors.
Cornell89
PostPosted: Mon Apr 19, 2021 8:12 am    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Problem solved!
The non-start problem was tangentially related to the dash removal. When I took out the dash I first disconnected the negative battery cable. When I did, I had to bend it a bit to keep it out of contact with the battery terminal. As you can see from the photo below, the original cable is in pretty poor shape. When I was trouble-shooting I did clean up the terminal ends, but I guess there were enough cracked wires under all that electric tape to inhibit current flow.
I replaced the original battery ground cable with a 4-gauge generic from Advance Auto this morning ($8+tax) and it started right up.
jlrftype7
PostPosted: Mon Apr 19, 2021 8:23 am    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Cornell89 wrote:
Problem solved!
congratulations, sometimes it’s the thing you were sure it wasn’t , since you had some electrical functions working.... Embarassed Embarassed Rolling Eyes Rolling Eyes
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Apr 19, 2021 8:53 am    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
Everyone should be inspecting their cable ends. This is from an '84 with intermittent starting issues.
The breaks are on the bottom side and not visible while the clamp was in situ.
Casey--
'01 Weekender --> full camper
y u rune klassik?
Cornell89
PostPosted: Tue Apr 20, 2021 5:55 pm    Post subject: Re: 83.5 1.9L crank no start after dash removal Reply with quote
What is most confounding to me is that a van can have a weak/damaged ground cable that's bad enough to prevent starting, but the starter still cranks strong and the plugs still spark.
