bug front leans to one side.
Ghettoman
Ghettoman is offline
PostPosted: Sat Apr 17, 2021 11:40 am    Post subject: bug front leans to one side. Reply with quote
Right front side of 67 bug front end leans one inch down on only that side. All other wheels are the same measurement from the ground to a edge. Shock is very good and no visible broken parts. What could it be? Tires are all inflated.
mukluk
mukluk is offline
PostPosted: Sat Apr 17, 2021 12:10 pm    Post subject: Re: bug front leans to one side. Reply with quote
Broken torsion leaves, trailing arms are sticking in the beam, or the ball joints on that side are binding.
Q-Dog
Q-Dog is offline
PostPosted: Sat Apr 17, 2021 4:36 pm    Post subject: Re: bug front leans to one side. Reply with quote
Aftermarket fender?
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Ghettoman
PostPosted: Sat Apr 17, 2021 7:43 pm    Post subject: Re: bug front leans to one side. Reply with quote
No I have had the car for 30 years. Never done this.
Ghettoman
PostPosted: Sat Apr 17, 2021 7:45 pm    Post subject: Re: bug front leans to one side. Reply with quote
I will check but I see nothing. By the way, I have never had the rear torsion bar rubber seals done. Should I go ahead and do this asap?
61SNRF
61SNRF is offline
PostPosted: Sat Apr 17, 2021 7:58 pm    Post subject: Re: bug front leans to one side. Reply with quote
The rear is more likely to sag side to side more than the front. If say the right front is higher it can be because the left rear is sagging.
Just to be sure you might try parking it on level ground and measure each corner the same way. This method rules out tire pressure......
Record, compare and relate the measurements.
-Bruce
An ounce of prevention is worth a pound of cure.
Ghettoman
PostPosted: Sat Apr 17, 2021 9:28 pm    Post subject: Re: bug front leans to one side. Reply with quote
the back measurements are the same on each side, the right front is 1.2 inches lower than the front left. You can visibly see it from the front view. Never seen this on my car before. The bug has over 400,000 on it but runs like a clock with great maintenance and care. I guess the front and rear torsion bars need to be looked at.
Ball joints replaced 7 years ago and a new steering dampner but that is it for the front. All 4 shocks replaced after 30 years with new Bilsteins last year.
Dan the workingstiff
Dan the workingstiff is offline
PostPosted: Sun Apr 18, 2021 2:19 pm    Post subject: Re: bug front leans to one side. Reply with quote
I read where you owned this 30 yrs.
Mine was leaning one way or the other and I measured all different way and I was coming up with different measurements the more I was measuring. It was driving me crazy. I parked on level pavement and crawled under the car and measured the same spots on the pan left to right front to back. It was within a 1/4". I learned to live with it and I finally don't see it anymore.....
'69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200
