k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Sat Apr 17, 2021 4:05 pm Post subject: Inlet Manifold gaskets woes |
Evening all
I’ve got a 2110 with cb 044 ultra mag heads and idas on scat tracs, it has an appetite for blowing inlet manifold gaskets (head to Manifold) I use the fibre gaskets which I match the ports and torque the manifolds down to 16 lbs ft with flanged m8 nuts. It’s not a difficult job I know but it is getting rather tedious
Never had this issue when I had the old drd heads with 44’s on CSP manifolds, used the same gaskets, hardware and torque setting. Scratching my head a bit now... is it down to poor quality gaskets? The lack of material between the inlet port? Would a sealant be better? Any thoughts or suggestions would be greatly appreciated.
Thanks |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Apr 17, 2021 4:18 pm Post subject: Re: Inlet Manifold gaskets woes |
Blown out? Or sucked in?
Blown out would be rather strange. But things happen.
Perhaps the intake valves are a little tight. Or your jetted o the lean side of things.
Sucked in. Are you sure that the manifold base is flat and true?
You can use Locktite 518 sealant in place of the gaskets.
But the head and intake manifold mating surfaces need to be flat, to get the sealant to work correctly. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
k@rlos Samba Member
Posted: Sat Apr 17, 2021 4:22 pm Post subject: Re: Inlet Manifold gaskets woes |
67rustavenger wrote: |
But the head and intake manifold mating surfaces need to be flat, to get the sealant to work correctly. |
Sucked in, Lash and jetting are spot on. The Manifolds are a few years old and used before I brought them so it’s a good possibility that it’s not perfectly flat. That’s something I will look into further
Thanks |
Posted: Sat Apr 17, 2021 4:42 pm Post subject: Re: Inlet Manifold gaskets woes |
I have a recent pair of JayCee intake manifolds.
I flattened the mating surfaces with a belt sander. Just to make sure that the mating surfaces are in good nik! _________________ I have learned over the years.
Buy Once, Cry Once!
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sat Apr 17, 2021 4:57 pm Post subject: Re: Inlet Manifold gaskets woes |
I flattened the mating surfaces with a belt sander. Just to make sure that the mating surfaces are in good nik! |
THIS
Also make sure the top of the "ears" that the fastening nuts hold against are parallel and flat. Otherwise you can have uneven torque on the studs. _________________ Glenn
Member #1009
#BlueSquare |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Sat Apr 17, 2021 5:14 pm Post subject: Re: Inlet Manifold gaskets woes |
Make sure the manifold will bolt on flat with no gasket......not hanging up on some edge or another. No "rocking" |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sat Apr 17, 2021 5:56 pm Post subject: Re: Inlet Manifold gaskets woes |
My manifolds hung up on the top cylinder tin. Had to trim it back a wee bit in a couple places. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
74 Thing Samba Member
Posted: Sat Apr 17, 2021 6:10 pm Post subject: Re: Inlet Manifold gaskets woes |
All the tips mentioned above about the manifolds being flat and easy on and off without interference and spread a small amount of loctite 518 on the bottom of the manifold with your finger and install (no gasket/no leak). |
Wreck Samba Member
Posted: Sat Apr 17, 2021 6:17 pm Post subject: Re: Inlet Manifold gaskets woes |
I use a flat piece of thick glass ,In my case a oven window from a scraped stove,spare bug windows work well and a sheet of coarser grit wet and dry sand paper .
Handy to surface all sorts of things . tops of cylinders etc .
The fibre type gaskets dry out over time and shrink , then you get and air leak , then an intake backfire from the lean mixture which blows out the gasket .
One engine I have has very small sealing surfaces , about a 1.5vmm in some places , I just use sealant no gasket after countless fibre gasket failures . The other engine has welded heads /manifolds ,good 5mm sealing surface all round , I use a fibre gasket and glue it to the manifold with a very light smear of ultra grey . I can remove the manifold and the gasket stays on the manifold to be used again . |
sled Samba Member
Posted: Sat Apr 17, 2021 9:09 pm Post subject: Re: Inlet Manifold gaskets woes |
zero gasket and this
_________________ drive your split. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sat Apr 17, 2021 9:18 pm Post subject: Re: Inlet Manifold gaskets woes |
You can use Locktite 518 sealant in place of the gaskets. |
For several years now, that's what I've been using also!
Thanks for the tip MCMSCOTT! _________________ Jesucristo es mi Señor y Salvador! |
k@rlos Samba Member
Posted: Sun Apr 18, 2021 1:03 am Post subject: Re: Inlet Manifold gaskets woes |
Thanks for your input people, I’ll have a tinker today and also order some 518
Many thanks |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
k@rlos Samba Member
Posted: Sun Apr 18, 2021 3:16 am Post subject: Re: Inlet Manifold gaskets woes |
UK Luke 72 wrote: |
I've been using black RTV, same as my cylinders get and it holds up fine, not difficult to clean up either. |
I’ve ordered some of the loctite the others recommended. Getting the right hump with it now
If it carries on I might fuck the stroker and ida’s off and get a 1600sp |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Sun Apr 18, 2021 3:27 am Post subject: Re: Inlet Manifold gaskets woes |
I would as many have said check the flatness of the manifolds. To do it properly you need an engineers flat block. Put stuarts Blue on the faces of the manifolds. Wait till it drys, then wrap some 600 paper around the flat blocks and flat the faces till the blue disapear's.. If this problem still happens, me personally would try another set of manifolds. I hope the head/seating surface is flat. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Apr 18, 2021 6:58 am Post subject: Re: Inlet Manifold gaskets woes |
k@rlos wrote: |
I use the fibre gaskets |
Hmm - I've always used the metal gaskets between the intake manifold and the cylinder heads. These exist for dual port. Single port heads use a simple metal/copper "ring" but the old seal must be first removed. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
Posted: Sun Apr 18, 2021 7:54 am Post subject: Re: Inlet Manifold gaskets woes |
Cusser wrote: |
k@rlos wrote: |
Hmm - I've always used the metal gaskets between the intake manifold and the cylinder heads. These exist for dual port. Single port heads use a simple metal/copper "ring" but the old seal must be first removed. |
Metal for stock heads, fiber for ported heads. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Apr 18, 2021 8:55 am Post subject: Re: Inlet Manifold gaskets woes |
Make sure the area on the manifold where the washers and nut"s fit is flat also. 99 percent of manifolds I see are just cast aluminium and the nut area is always ruff cast and not flat.
If the porting is big and the gaskets are thinon the edges you may also need to weld them to thicken up the thin part of the gasket.
Pics are needed |
k@rlos Samba Member
Posted: Sun Apr 18, 2021 10:01 am Post subject: Re: Inlet Manifold gaskets woes |
I’ll blue up the manifolds bases tomorrow and bolt down to see if they and the head surfaces are flat. Will check the surface where the nuts go too, my manifolds have plenty of material around the outside edge but the split between the 2 ports is quite tight. |
