brinleydavis Samba Member
Joined: November 09, 2020 Posts: 43 Location: Alberta, Canada
Posted: Sat Apr 17, 2021 8:07 pm Post subject: Type 4 heads |
Hi everyone!! Back at it after a long, unproductive winter, and back to rebuilding my type 4 for my bay! I’m reassembling now, while watching old bug me DVDs that my dad had, and everything is going smoothly!
Looking for someone that is able to give me a better idea of the condition of my valve seats.
Both heads are pretty even as far as wear goes, and I’m rebuilding this more as a fun project than a serious build. That being said, i do want to do a good enough job that I won’t be stranded with a green bus somewhere lol. Here’s some pictures, any info will help.
Also, there seems to be more wear on one side than the other, you’ll see what I mean in the pictures. Does anyone have an idea of what would be causing this? Thanks!!
[/quote] |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Sat Apr 17, 2021 9:13 pm Post subject: Re: Type 4 heads |
Those heads are a hand grenade ready to blow. If you try to use them you’re risking catastrophic engine failure. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun Apr 18, 2021 1:18 am Post subject: Re: Type 4 heads |
aeromech wrote: |
Those heads are a hand grenade ready to blow. If you try to use them you’re risking catastrophic engine failure. |
Those heads have already seen a catastrophic engine failure or two. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sun Apr 18, 2021 4:07 am Post subject: Re: Type 4 heads |
Into the scrap pile.
New AMC castings or nothing. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Sun Apr 18, 2021 7:01 am Post subject: Re: Type 4 heads |
those heads on your "fun" engine would surely cut down on the fun. if you want to keep it fun, use any heads but those.
ALso, everyone on here is going to tell you to have any heads redone /looked at by a pro, and you will never get a "looks good!' run them!" unless you do an unboxing from len hoffman. |
Posted: Sun Apr 18, 2021 8:23 am Post subject: Re: Type 4 heads |
What typically kills Type 4 heads is either the seats coming loose and wearing their way down into the soft aluminium of the heads, cracking through the spark plug hole or exhaust port, or all of the above.
If the seats are tight and there is no cracking (both unlikely) you might be able to have a shop replace the guides and the exhaust valves and get years out of them if you are only driving a couple of thousand miles a year, but if you are hoping to drive 10K miles per year, you will be back in there soon to replace them so you might as well drop the big bucks now. |
BerneseMtnDog Samba Member
Posted: Sun Apr 18, 2021 1:49 pm Post subject: Re: Type 4 heads |
When I unboxed my heads from Len Hoffman it felt like Christmas and they were a thing of beauty. No regrets dropping the bucks on those heads.
Steve |
Posted: Mon Apr 19, 2021 6:04 am Post subject: Re: Type 4 heads |
BerneseMtnDog wrote: |
Steve |
sounds great! run them! |
Posted: Wed Apr 21, 2021 5:18 pm Post subject: Re: Type 4 heads |
Thank you everyone!! Although not the news I wanted, I figured that’s what I’d be getting back. I have one more type 4 engine sitting here that might be in better condition. I’m hoping, since new heads are so expensive! Has anyone ever heard of re seating the valve seats? Another set I have are in better condition, but the one seat is slightly popped out! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Apr 21, 2021 6:31 pm Post subject: Re: Type 4 heads |
brinleydavis wrote: |
Suck it up and let the moths out of your wallet, those heads are cooked too, spend now, or spend more later on the side of the road.
There's a few must do's on most cars, brakes and steering for example, type 4 bus owners also get a bonus "must do" on their list, and that's heads.
Hint:, it's much more pleasant replacing them in your driveway than in the middle of nowhere. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Apr 21, 2021 10:20 pm Post subject: Re: Type 4 heads |
You could have larger valves and matching larger seats installed, but if you are going to spend that kind of money, why spend it on old worn out heads? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21510 Location: Oklahoma City
Posted: Thu Apr 22, 2021 10:13 am Post subject: Re: Type 4 heads |
Sure....you could make decent set of worn out heads...just like new.....but you may not be able to afford it.
You can have the cylinder seats re-machined....any cracks welded....new oversized seats installed....new studs and threads....thread inserts for the spark plug holes. You will need new oversized valve guides.
BUT....after welding and before machining and installing seats and new studs....the heads would have to be annealed. That is what makes the heads ....just like new....aside from cracks.
Not many shops around that still anneal heads except racing shops. Its not hard. You just need to have the oven and the experience/knowledge.
It may be cheaper to buy new castings. Ray |
