67ctbug Samba Member
Posted: Sat Apr 17, 2021 9:04 pm Post subject: Valve Adjustment Woes |
I’m having a real tough time here... my bug ran okay, but broke down when I was cruising. Couldn’t get the thing to start again. Put in new plugs, wires, coil, and reset timing and it started but ran rough so I decided to adjust the valves. Pretty simple, get ‘me set to .006 and everything is good. Go to start and it tries, starts firing and dies. Makes a noise too, like I can hear air rushing out. Any ideas? I should note that 1-2 cylinders had zero play and needed adjustment while 3-4 were basically good needing minor adjustment. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
steviewde Samba Member
Posted: Sun Apr 18, 2021 12:17 am Post subject: Re: Valve Adjustment Woes |
Perhaps you can decribe HOW your bug broke down.
Did it stop immedialtely? Silent or loud?
the "Stevie" _________________ Being different, or being boring?
My projects:
"Sparkäfer", 1973
Karmann Coupé 1966
VW1302S, 1971
VW1303S, 1973 |
Posted: Sun Apr 18, 2021 7:31 am Post subject: Re: Valve Adjustment Woes |
I was going along at about 50 then it just started losing acceleration. Pulled over and couldn’t get it to start again. Honestly think I overheated it because I’m an idiot and the fan shroud things had been open . _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Apr 18, 2021 7:38 am Post subject: Re: Valve Adjustment Woes |
67ctbug wrote: |
I’m having a real tough time here... my bug ran okay, but broke down when I was cruising. Couldn’t get the thing to start again. Put in new plugs, wires, coil, and reset timing and it started but ran rough so I decided to adjust the valves. Pretty simple, get ‘me set to .006 and everything is good. Go to start and it tries, starts firing and dies. Makes a noise too, like I can hear air rushing out. Any ideas? I should note that 1-2 cylinders had zero play and needed adjustment while 3-4 were basically good needing minor adjustment. |
This is suspect.
Make sure that you are at TDC for the #1 cylinder. Then run through valve lash adjustment again.
If you have to. Remove the crank pulley bolt and verify the keyway is pointing toward the 9:00 position while the pulley is at TDC for #1.
What the above description says to me is. You started your adjustment at TDC for the #3 cylinder.
But as always. I could be wrong on this. I'm not there to witness what you have done. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Sun Apr 18, 2021 8:06 am Post subject: Re: Valve Adjustment Woes |
The sound of air rushing out sounds like you might have a stuck or bent valve, ie, lost compression. Doublecheck the height of the valve springs and clearances. _________________ Come on, It's not rocket science. KISS |
Posted: Sun Apr 18, 2021 8:20 am Post subject: Re: Valve Adjustment Woes |
raydog wrote: |
The sound of air rushing out sounds like you might have a stuck or bent valve, ie, lost compression. Doublecheck the height of the valve springs and clearances. |
... this was my first idea, too, as I read it.
Overheated, burnt valve.
.... perhaps ...
My projects:
"Sparkäfer", 1973
Karmann Coupé 1966
VW1302S, 1971
VW1303S, 1973 |
aa390392 Samba Member
Posted: Sun Apr 18, 2021 8:47 am Post subject: Re: Valve Adjustment Woes |
Do a compression test.
If its low go to parts store and buy a couple cans of compression. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Sun Apr 18, 2021 7:57 pm Post subject: Re: Valve Adjustment Woes |
Well, I've got it running. Doesn't sound awful. Went through the valve adjust process again and all was well. Tightened up a couple that were too loose from my first go. Will still do a compression check. Now my problem is the carb, the accelerator pump won't pump so I can't give it gas. Gonna replace it as I've rebuilt it and no dice. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Sun Apr 18, 2021 8:10 pm Post subject: Re: Valve Adjustment Woes |
67ctbug wrote: |
Now my problem is the carb, the accelerator pump won't pump so I can't give it gas. Gonna replace it as I've rebuilt it and no dice. |
Just take the carb apart and clean it again. Then next day clean it again. Helps a lot to soak it over night each time in a 1 gallon can of Berryman's carb cleaner. Found long ago that cleaning a carb usually loosens up crud, but does not get it out. Cleaning it twice more does the trick. _________________ In Stereo, Where Available! |
Posted: Sun Apr 18, 2021 8:14 pm Post subject: Re: Valve Adjustment Woes |
Eric&Barb wrote: |
67ctbug wrote: |
Just take the carb apart and clean it again. Then next day clean it again. Helps a lot to soak it over night each time in a 1 gallon can of Berryman's carb cleaner. Found long ago that cleaning a carb usually loosens up crud, but does not get it out. Cleaning it twice more does the trick. |
It's been through an ultrasonic _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun Apr 18, 2021 8:24 pm Post subject: Re: Valve Adjustment Woes |
67ctbug wrote: |
It's been through an ultrasonic |
Then do it again.
Also do post images of the engine. That way all of us here can point out any obvious problems. _________________ In Stereo, Where Available! |
Posted: Sun Apr 18, 2021 8:48 pm Post subject: Re: Valve Adjustment Woes |
Send it off to volkzbitz he'll make better than new, he does the bushings, they wear out and rebuild kits dont do it..wise investment...get your same carb back. Just an fyi _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Mon Apr 19, 2021 9:51 pm Post subject: Re: Valve Adjustment Woes |
Right so here’s the current state. My buddy gave me a Bocar H30/31. Put it on and it starts good. My current carb was a 30 pict-2, so if I buy anything from Tim it’s gonna be the correct carb for a ‘67. Engine was still smoking so I retorqued the head, all bolts were loose, reset the valves, and then it fired right up. Runs okay IMO. I’ll post some pictures tomorrow. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Apr 20, 2021 5:36 pm Post subject: Re: Valve Adjustment Woes |
Hopefully you retorqued all eight nuts on the one head. Otherwise it can tilt.
If you take the engine down to a long block it is far better to retorque the engine case fasteners first in same sequence as if one is building an engine. Then torque all the head nuts. It is amazing how loose all of those can get. _________________ In Stereo, Where Available! |
Posted: Fri May 07, 2021 3:07 pm Post subject: Re: Valve Adjustment Woes |
Well, you’ll see me in a new thread soon.
First time dropping an engine, 1 hour. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Fri May 07, 2021 3:35 pm Post subject: Re: Valve Adjustment Woes |
67ctbug wrote: |
First time dropping an engine, 1 hour. |
Awesome!! Just do take your time when putting it back in.... _________________ In Stereo, Where Available! |
Zundfolge1432 Samba Member
Posted: Fri May 07, 2021 6:55 pm Post subject: Re: Valve Adjustment Woes |
While you got it out I’d turn the generator to correct position.
Never heard of rebuilding a carb three times but I did know a guy that turned light switch on off 3 times when he entered a room. 😀 |
Posted: Fri May 07, 2021 7:05 pm Post subject: Re: Valve Adjustment Woes |
Zundfolge1432 wrote: |
While it's out I'm doing everything I can to not take it out for a while. Inspecting clutch, looks new to me, paint/ repair tins, new engine seals. Basically going to strip to a long block and see what's wrong with the head. When I checked the valves again last night they had tightened up on the 1-2 side again so my pre-inspection thought is the head studs are pulling out. That put me over the edge and I dropped the motor _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
