Any photos of Bugs running same size front and rear tires
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
H82WRK
H82WRK is offline
PostPosted: Sun Apr 18, 2021 9:02 am    Post subject: Any photos of Bugs running same size front and rear tires Reply with quote
Any type of wheel is fine. Just looking to try to see a set of example 185 50 15 on the front and back. Everything I see everybody’s got a larger rear tire and a smaller front tire. If anybody’s got photos of it on a lowered Bug with a swing axle... even better.
Thanks so much!!
Rachael
hopkin Premium Member
hopkin is offline
PostPosted: Sun Apr 18, 2021 7:22 pm    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
Thanks so much!!
Rachael
Not lowered, but Swing Axle with 185 65 15 on my car, front and back:
1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car)
H82WRK
H82WRK is offline
PostPosted: Tue Apr 20, 2021 9:59 am    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
Thank you Hopkin!!! That’s exactly what I was looking for. I have 185 on the front of my bug with 205 in the rear. Wanted to match the fronts and run 185 all around. Knew it wasn’t a huge difference in size but still wanted to get a visual. You are the best!!!
johnnyvw164
johnnyvw164 is offline
PostPosted: Wed Apr 21, 2021 7:07 pm    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
185/65-15's on mine as well...
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Apr 21, 2021 7:10 pm    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
195/60-15 all around. 3" drop front and 1" rear.
Glenn
Member #1009
#BlueSquare
vwchad
vwchad is offline
PostPosted: Tue May 11, 2021 11:55 am    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
185/70 15s all around on 4.5" Vintage 190 wheels. Car is a 63.
Stock Steve
Stock Steve is offline
PostPosted: Wed May 12, 2021 7:54 am    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
Refinished 14x6 US Mag 5-slots, with 205/70R14 radials. Stock suspension.
Stock Steve
Shoreline Antique Auto Connection
http://www.shorelineantiqueautoconnection.com/
Ich Bin Ein Facebooker: https://www.facebook.com/steve.fromsaac
Join VVWCA: http://www.vvwca.com/
Your source for old school metal tire valve caps: http://www.thesamba.com/vw/classifieds/detail.php?id=1416217
Thanks Veterans
jhogan59
jhogan59 is offline
PostPosted: Sat Jun 26, 2021 4:39 pm    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
I have a '59 in the planning stage. Please share your suspension setup - dropped spindles, drums or disks, narrowed beam, rear drop, etc.
If I can fit 175/65s (or wider) on Vintage 190s with 2.5" dropped spindles and a stock beam I think I'll be a happy camper. Being able to do it with disks would be icing on the cake.
vwchad
vwchad is offline
PostPosted: Tue Jun 29, 2021 12:32 pm    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
PM sent with details.....
In short, with my particular set up, I didn't like dropped spindles. They didn't work well for the rest of my suspension to give me what I was after.
boostretard
boostretard is offline
PostPosted: Sun Oct 03, 2021 12:05 pm    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
72 standard with 195/65/15 all around on 15x4.5” smoothies on wide 5 conversion
Car is “nominally” level and front is air adjustable but riding primarily on torsions. Drop spindles and adjustable rear plates.
Others in my gallery:
https://www.thesamba.com/vw/forum/album_search.php...ts=summary
BruceJ
BruceJ is offline
PostPosted: Thu Oct 21, 2021 5:55 am    Post subject: Re: Any photos of Bugs running same size front and rear tires Reply with quote
Beautiful! Thinking of a similar setup for my '65, same wheels (if I can find them). With the Vintage 190's (which I suppose have thicker mounting flanges), what size lug bolts or nuts/studs did you use?
1965 Beetle
1972 Westfalia
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
