yoursurfer Samba Member
Joined: August 26, 2003 Posts: 97 Location: Salado Texas
Posted: Sun Apr 18, 2021 11:31 am Post subject: What exhaust to use on Subaru 2.2 swap into bay window |
Whats best exhaust to use ofn a Subaru to bay swap, anyone with expierence?
I current have a header with a motor cycle pipe on end, like to it to be more quirt and hidden _________________ 1973 914 2.0 Porsche
1972 Bay Window Deluxe "Busaru"
1967 Beetle "Ruby" Hot VW's Feature Car"
1966 Mini Cooper Countryman
1965 Mini Cooper Sedan |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Sun Apr 18, 2021 2:22 pm Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
I bought mine from the company that sold me the conversion parts but any custom exhaust should be able to help you _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sun Apr 18, 2021 9:37 pm Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
i just make my own. i don't like how some of them are set up and run too close to the timing belt and or the thermostat/coolant hoses _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1181 Location: Vancouver, BC
Posted: Mon Apr 19, 2021 4:22 pm Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
If you have a 2.2L with dual port exhaust then KEP makes a decent (but pricey) header that also fits a 2.5L SOHC in case you want to upgrade later. I used one for my 2.5L swap into my 76 Westy and it worked out nicely. I also used a catalytic converter from a Vanagon and a Bug Pack muffler and it has good clearance from the plastic timing covers and coolant lines so I don't use a heat shield.
https://www.kennedyeng.com/subaru-vanagon
DB _________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 536 Location: Talbott, TN
Posted: Tue Apr 20, 2021 4:56 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
Have you looked at the OEM muffler setup on a Subaru BRZ? It’s pretty compact and fits right under the engine. A ton of Engineering goes into the factory exhaust system to create the perfect balance of power, efficiency, and sound Specific to the engine.
Posted: Tue Apr 20, 2021 8:01 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
that is the catalytic converter, not the muffler. _________________
Jake Raby wrote: |
Brian wrote: |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Tue Apr 20, 2021 8:35 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
skills@eurocarsplus wrote: |
i just make my own. i don't like how some of them are set up and run too close to the timing belt and or the thermostat/coolant hoses |
Do you have a preferred supplier for the parts? I'm about there. My SC header just keeps cracking. |
panel Samba Member
Posted: Tue Apr 20, 2021 9:16 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
FWIW.....I bought my primaries from Outfront then bought some mandrel piping in 90° and 180° then made my own up to the muffler of my choice. You can by flanges or buy some v-band clamps for better fitment. Maybe build off the factory heavy primaries? Is yours a dual exhaust port ? _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Thu Apr 22, 2021 12:16 pm Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
That box under the engine in my last post looked more like a primary muffler than a catalyst (it's pretty big for a cat), so I'm guessing the typical Suby to bus swap guy or gal would go without a cat. I personally like running catalytic converters, just to get rid of the stinky exhaust. The new cats are pretty efficient these days and take away virtually nothing from a performance perspective. I'd also think it would be pretty difficult to use the Subaru Power Control Module without an upstream and downstream O2 sensor input from the Catalyst (well that is if you don't mind the malfunction indicator light on all the time.....) |
Posted: Thu Apr 22, 2021 2:10 pm Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
Screen shot of the exhaust from my swap. Enough room for a trailer hitch and with the bumper on, you can't see the exhaust.
Click to view image
Posted: Thu Apr 22, 2021 6:34 pm Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
Sweet looking setup! Looks like you got an aftermarket catalytic converter on there also. If you appreciate quiet, consider adding a resonator. I experimented with adding one to the cheap PaceSetter muffler on my type 4 air cooled motor and it made a significant reduction in noise. I bet you could find one from a Subaru Forester or similar that is tuned to attenuate the exact frequencies the Suby motor makes. Could also fit between your cat and muffler. Since I don’t actually have a Suby swapped bus, take my comments as suggestion only. I think Skills or Vdubnut may have real world experience to share |
Posted: Thu Apr 22, 2021 9:17 pm Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
alaskadan wrote: |
i just buy a bunch of pipes from summit or jegs (same crap, just depends on what else i am ordering)
i try and build off the factory Y pipe. works well mostly unless the bus is slammed, then it's plan B _________________
Jake Raby wrote: |
Brian wrote: |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1184 Location: Dallas, GA
Posted: Fri Apr 23, 2021 9:22 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
I used the Rocky Mountain Westy (now VanCafe) stainless header, and added my own muffler and hanger. Fits very well, isn't too loud (but louder thank stock), and has a very nice exhaust note.
Header:
https://www.vancafe.com/RMW-SSEDP-4-p/rmw-ssedp-4.htm
Muffler:
Its a walker round body aluminized muffler. I'd have to dig up the PN
Upskirt pic:
From the back:
The passenger side bank primary pipe does run close to the water pump inlet connection, but there is plenty of room to work around it. I've had ZERO issues with any heat radiation from the header to the coolant pipes. Pic below from back when I was mocking it all up. I'm at 2.5 years and 10k miles on this arrangement now.
I've been extremely happy, and wouldn't change anything about the system. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
74 Transporter (EJ25 Swapped) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Posted: Sat Apr 24, 2021 12:04 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
69BahamaYellow wrote: |
Thanks 69BahamaYellow.
It's actually quieter than the aircooled was so I'm really happy with how it turned out. The Bugpack muffler is surprisingly quiet. _________________ *******************************
Posted: Sat Apr 24, 2021 12:10 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
Vee Dub Nut wrote: |
The passenger side bank primary pipe does run close to the water pump inlet connection, but there is plenty of room to work around it. I've had ZERO issues with any heat radiation from the header to the coolant pipes. |
that's crazy. we tried that setup on davearks bus and i grabbed an extra 10* of heat.
for some reason, i think the one i used ran a bit closer to the t-stat. not shitting on it, if it works i'd call it a win _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Apr 26, 2021 9:14 am Post subject: Re: What exhaust to use on Subaru 2.2 swap into bay window |
for some reason, i think the one i used ran a bit closer to the t-stat. not shitting on it, if it works i'd call it a win |
Yea, I remember you telling me that when I was originally building it. I already had all the stuff though, so I continued on with the RMW header. Obviously something in the two setups were different, since I've had no issues with mine.
Although it is close, I don't feel like its too close if you route the line carefully. I maximized the space around the rigid coolant line when I built it. I suppose some of the variations in the water pump and tstat housing could play into things too though. _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (TBD)
