matthewl Samba Member
Posted: Sun Apr 18, 2021 2:04 pm Post subject: Bus or bug trans? |
So this is my question for the trans guys. Would a "Pro Street " IRS type one trans or a mostly stock 002 bus trans with the berg intermediate housing be best?
My thinking on the mostly stock bus trans is it would have the stronger side gears and stronger R&P, plus type 2 CV joints. I know the main shaft and gears are the same strength as a type one in the 002, so no gain there.
Plus the type 2 would not have a super diff.
I know a type one should be fine for my application but just thinking for a few dollars more the type 2 has the better side gears, if I added that to the type one it would massively increase the cost.
This is going in a fiberglass manx buggy with a
2332cc with 42x37 ported heads, c-95 cam, around 9:1 compression, 44 idf and 1/5/8" exhaust
Primary use is street with the three or four trips a year to the drag strip.
And yes I know an 091 is way stronger but don't want to go down that rabbit hole. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7212 Location: Videbaek Denmark
Posted: Sun Apr 18, 2021 2:27 pm Post subject: Re: Bus or bug trans? |
For a buggy, in that power range I wouldnt bother. Give Kevin @ KCR a bell and get one of his Super street plus or Pro street type 1 transmissions. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15302 Location: Deep in the 405
Posted: Sun Apr 18, 2021 4:36 pm Post subject: Re: Bus or bug trans? |
If your gonna drag race with slicks get the Bus box. If your gonna drag race with DOT radials or street tires then you can get by with the Bug box on a lightweight Buggy. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Sun Apr 18, 2021 4:46 pm Post subject: Re: Bus or bug trans? |
Folts tries to talk everyone into a bus box if IRS is an option, by the time you build a strong type 1 the cost to go bus is very little more. Stronger and larger R&P better internals with less upgrades needed over a type 1
This is if you are going all out on the type 1, Dave Folts builds the trans for what you want, He does not have fancy names like freeway flier or pro street. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Mon Apr 19, 2021 6:54 am Post subject: Re: Bus or bug trans? |
With the exception of the gears in the diff being bigger, a stock 002 Type 2 5.38/4.86 r&p is actually weaker than a Type 1 3.88 r&p. The main strength advantage of a Type 2 is in the wider 091 gears, and a 4.57/4.13 r&p. The bottom line is, what tires you will be using, and how hard you plan on abusing it at the track. If you’re planning a more off road version of a buggy with 28-30 inch tires, a stock geared 091 with a super diff would hold up to some abuse for a while. If you don’t want to go down the rabbit hole of an 091 trans. because of cost, either don’t take the buggy to the track, or save more money. |
Posted: Mon Apr 19, 2021 9:46 am Post subject: Re: Bus or bug trans? |
sorry, my example was with a 4.13 from weddle. not the stock R/P on the 002
Dave said the good core is 400.00 for a 002 and the R/P is under 1k, using what the good core has and upgrading the R/P and a few other parts is the smart way to go, better foundation to go from in the future. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
Posted: Mon Apr 19, 2021 10:40 am Post subject: Re: Bus or bug trans? |
Thanks for the info guys. Yes a bus box is probably over kill and adding complexity and it sounds like there's not much advantage to the 002. But just trying to way my options for future growth.
So I guess a better question is a stock rebuilt 091 stronger than a IRS type 1 with a super diff, 4.12 R&P, 3.80 first, welded 3/4 hubs and chromoly pinion retainer?
Both of those trans cost almost the same, but the 091 has more room to grow from what it sounds like.
How bad is the shifting on a stock rebuilt 091 with the 10° mount?
A friend of mine has the 10° mount with a wore out 002 trans in his baja and it sucks to shift.
Thanks again guys for putting up with my question. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Mon Apr 19, 2021 2:10 pm Post subject: Re: Bus or bug trans? |
I have a stock 3 rib 002 with a 2332, tims stage 2 heads, web 252 and 1 5/8” exhaust and haven’t broke it.
I’ve been running the 10 degree for years and haven’t had issues. I did replace the guide rod bushing and use a early rubber nose cone coupler or whatever it was called.
I did manage to kill a stock type 1 transmission though.
An 091 would be nice and I wish I would have went that route in the first place. The 002 is clearly bigger than the bug trans, people knock the 3 rib internals but I haven’t had issues.
When I ran a full body I did have clearance issues at the exhaust and tin didn’t fit like it should to the apron using the 10 degree. Also makes getting to the engine bolts and cooling fan nut suck.
If you use the intermediate housing you don’t need the 10 degree. |
Posted: Mon Apr 19, 2021 2:23 pm Post subject: Re: Bus or bug trans? |
matthewl wrote: |
Thanks again guys for putting up with my question. |
Yes, an 091 will have a wider 3.78 1st gear, and the most durable differential gears in stock form. A super diff added to an 091 shouldn’t add to much to the overall cost, but will add significant durability. If you need an outright trans, do some research on core prices from whoever you decide to get the trans from. Some shops I know of have increased core values on Type 2 trans 400% in the 16 years I’ve worked on them. That’s usually about 300% of what a Type 1 core is.
The conversion intermediate housing not only enables the shifting mechanism to enter the pan a little better, but eliminates some of the additional linkage in a Type 2 trans. For daily driving, the stock mechanism will be fine, but it will hinder you in quick shifting at the track. |
Wreck Samba Member
Posted: Mon Apr 19, 2021 2:43 pm Post subject: Re: Bus or bug trans? |
what size rear tyres are you planning to run ? |
Wreck Samba Member
Posted: Mon Apr 19, 2021 3:25 pm Post subject: Re: Bus or bug trans? |
matthewl wrote: |
N50-15 tires = 28" tall |
My choice for that tyre size on a budget would be a good S/H 5 rib 002 . 4.86 diff and fair ratios stock . There are some simple gear shift solutions . Not ideal for drag racing but if you plan to drive on the street 99% of the time they work ok .
A type 1 with a strong 3.88 would be too tall geared in my opinion . Edited , forgot it was not being used off road , so low 3rd ,4th would work . And give you longer 1st/2nd .
If you look at a S/H box , grab the input shaft , if you can push it in and out , then the box is worn out and the housings flogged . If the shaft is solid , it can select all gears , oil looks ok , then there is a fair chance the box will be ok to use .
Posted: Mon Apr 19, 2021 4:25 pm Post subject: Re: Bus or bug trans? |
I don’t get what the issue with the shifter is.. yeah there’s an angle there but when you set the length of the nosecone mount you can reduce the angle by putting the nose cone towards the top of the hole in the car. I didn’t notice a difference in feel going from a bug trans too a bus. I don’t have a short throw shifter though and can see potential issues there. I also didn’t use the box style coupler but instead used a early doughnut style. The dimple will be on the wrong side but hasn’t been a issue for me and I don’t remember adding a dimple.
Going to the 10 degree it did show the nose cone seal leaked..
I have the 5.38 R&P with 235s in back. For the speed limits here it’s perfect but in Alaska the max speed limit is 55 MPH. Town is 25 MPH. Iirc I’m around 3400 rpm at 55. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Apr 20, 2021 5:14 am Post subject: Re: Bus or bug trans? |
I've ran those tires on the street and tried to drag race too ,they only have a contact patch of a few inches like 2" or 3"when launching
so that said , stick with a Type 1 box , add a super diff and some type2/181 drive flanges for the bigger axles , I have about 5 years on my trans an many passes down the strip with 6" and 7' wide slicks , without any problems and that was with the heavy turbo bug which has purty good torque/power
buggy had a built 2332 w/ida and was purty quick too _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Tue Apr 20, 2021 8:06 am Post subject: Re: Bus or bug trans? |
So I'm thinking a rebuilt stock 091 is the way for me to go. Sounds like it is as strong as a " PRO STREET" type box, plus it leaves room to grow for the future. It also has a better gear ratio for the 28" tall tire, will just use the 10° mount and stock shifter. Thank you guys for all the information it has helped a lot. _________________ Check out all the Air-cooled fun on my YouTube channel https://m.youtube.com/channel/UCl9IVR1svnDmH1i6yQ4_o1Q?view_as=subscriber |
Posted: Tue Apr 20, 2021 10:29 am Post subject: Re: Bus or bug trans? |
matthewl wrote: |
So I'm thinking a rebuilt stock 091 is the way for me to go. Sounds like it is as strong as a " PRO STREET" type box, plus it leaves room to grow for the future. It also has a better gear ratio for the 28" tall tire, will just use the 10° mount and stock shifter. Thank you guys for all the information it has helped a lot. |
The 4.57 r&p would work well with a 28 inch tire. Get a 4 spider diff. If you don’t think the cast ones are good enough, or don’t want to spend the money on the race one, get an OEM VW one from a Vanagon. |
77charger Samba Member
Posted: Tue Apr 20, 2021 8:45 pm Post subject: Re: Bus or bug trans? |
I ran an 091 case with all weddle geared 002 internal 4.57 weddle ring pinion too.7 years of duning no wear on gears.Engine was 2275
Now using a 3.5 honda ring and pinion looks good after 2 seasons and gears look good too. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Bad bug Samba Member
Posted: Wed Apr 21, 2021 1:22 am Post subject: Re: Bus or bug trans? |
77charger wrote: |
Now using a 3.5 honda ring and pinion looks good after 2 seasons and gears look good too. |
What was it like to drive the 091 box with the 2276cc t1, did it accelerate quickly, did you also have good topend speed, reason for me asking is your 2276 with 40 x 35.5 valve should have a lot of torque i want feed back on this setup as i also have an 091 that i want to put on a 2.2ltr web86b oxyboxer with panchitos going in a 72 beetle. |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Tue Apr 27, 2021 6:32 pm Post subject: Re: Bus or bug trans? |
ivkings4 wrote: |
This is if you are going all out on the type 1, Dave Folts builds the trans for what you want, He does not have fancy names like freeway flier or pro street. |
I've always enjoyed talking to Dave, he's mentioned to go bus a few times with me as well. I think he makes a U joint adaptor for bus boxes for even the swing guys if I remember right. I always thought that was pretty slick. _________________ T1 IRS Rebuild Book on Lulu.com
http://www.lulu.com/shop/tim-marshall/t1-irs-transaxle-book/paperback/product-24055997.html
As seen in Volks America Issue 14 Page 11 (Full page review) |
