Early ignition switch. 3 screw terminal
Smiths Bugs
Smiths Bugs is offline
PostPosted: Sun Apr 18, 2021 8:27 pm    Post subject: Early ignition switch. 3 screw terminal Reply with quote
I recently acquired this switch in a box of supposed oval parts I have don’t my research and narrowed it down to around 57-59 or said a forum that is when they switched from 4 to 3 terminals but I can’t say for certain I would really appreciate the help identifying this switch! Thank you!
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Apr 18, 2021 10:03 pm    Post subject: Re: Early ignition switch. 3 screw terminal Reply with quote
1958-1960 Bus based upon the mounting bracket. ovals have a much longer mounting bracket.
Roads Scholar &
PostPosted: Sun Apr 18, 2021 10:06 pm    Post subject: Re: Early ignition switch. 3 screw terminal Reply with quote
3 to 4 Oval change theory HERE
L code is 1967 so 1967 Bus
Confused why it's screw terminal though, not sure I've ever seen a screw-terminal L code ignition.
I wondering if someone assembled the screw-terminal backing on a later ignition front?
Screw terminal ignitions also don't have a solid bracket like the, it's more of a bent "open" bracket.
Bus ignitions have the bracket in the center like your ignition, Beetle brackets are offset to the side a little, at least for later ones that would also be L-code.
Ovals are center bracketed like that as far as I know.
1959 Bus ignition example
1967 Bus ignition
