Quick question - 1966 deluxe tire
markeaton
markeaton is offline
PostPosted: Mon Apr 19, 2021 10:06 am    Post subject: Quick question - 1966 deluxe tire Reply with quote
Hello-
I need new tires for the 1966 13-window I am restoring. Before I do buy them, I have a question.
I have found different information on tires, about whether or not whitewall or no-whitewall. Can't seem to find a definitive answer.
Were whitewall tires considered original or is it just a matter of preference?
Thank you
-Mark
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Apr 19, 2021 12:10 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
If you mean "original" as in from the factory on the bus, that is a good question. They were available from the dealership though.
Listed in the "Damage Numbers" manual here:
http://www.oacdp.org/
In Stereo, Where Available!
markeaton
PostPosted: Mon Apr 19, 2021 12:14 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
While I bought this about 50-60% restored, what is remaining, I'd like to get as "off the factory" with things as much as I am able. Thanks !!!
markeaton
PostPosted: Mon Apr 19, 2021 12:21 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Sorry Eric, I hit enter too fast. If I am reading it right, looks like whitewall is listed.
Eric&Barb
PostPosted: Mon Apr 19, 2021 12:30 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Yes, yes it does. Just not sure if those were on the bus from the factory or factory supplied tires to the VW dealerships that the VW dealers were reporting if later there was a problem.
Eric&Barb
PostPosted: Mon Apr 19, 2021 12:33 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
From the 1966 VW Dealer accessory manual:
markeaton
PostPosted: Mon Apr 19, 2021 12:50 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Well, this is getting interesting ha-ha. I could go either way with non-white or white. Thank you Eric for posting.
A quick internet search on 1966 vw bus deluxe shows the majority with whitewall. And some with the "wider" white, coker classic.
Eric&Barb
PostPosted: Mon Apr 19, 2021 4:30 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Note 1500 options on Page 2....
https://www.thesamba.com/vw/archives/lit/66exportpricelist.php
hitest
hitest is offline
PostPosted: Mon Apr 19, 2021 6:11 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
https://www.thesamba.com/vw/archives/pressphotos/66deluxe_1a.jpg
A neat shot from the archives here. Looks like bias plys to my eyes.
FU#5
John Ghia
John Ghia is offline
PostPosted: Mon Apr 19, 2021 8:11 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
M code 091 is white wall tires
BUS BOYZ
PostPosted: Mon Apr 19, 2021 9:40 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Yep. Thin whitewalls were an option for 1966.
Wide whites were earlier Buses.
I don't think it had to be an M-code thing though, you could upgrade at the dealership when new too.
I know I've seen them listed on various dealership price lists
Here's a 1966 price list from NY I found in the Gallery
Whitewall tires for Buses in the lower right - $35
markeaton
PostPosted: Tue Apr 20, 2021 4:54 am    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Thank you to all replies.
Whitewall (thin lined) is what I'll be putting on.
mandraks
mandraks is offline
PostPosted: Tue Apr 20, 2021 6:45 am    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
a 66 would have 7.00-14 bias plies, tubeless.
regards
Uli
markeaton
PostPosted: Tue Apr 20, 2021 7:29 am    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
mandraks.... i looked that up... saw mostly images of non-whitewall and some whitewall... is non-white what you are suggesting? Thank you.
mandraks
mandraks is offline
PostPosted: Tue Apr 20, 2021 9:10 am    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
no not at all. only saying the proper size of the tire for 66-67 was 7.00-14 rather than 6.40-15 on the previous years.
Both sizes are available in Black, Thin or wide whitewall.
So if you have the stock 14 inch wheels, then 7.00-14 bias ply would be the appropriate stock tire.
I personally love how Bias ply tires ride. SOO comfortable. However, they are more expensive than say a 185/14 radial tire. they also do not last as long, and they definitely squeal when you go around corners like you would with a more modern car.
regards
Uli
markeaton
PostPosted: Tue Apr 20, 2021 10:04 am    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Ah gotcha you. Thank you mandraks.... great feedback.
markeaton
PostPosted: Tue Apr 20, 2021 1:10 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
mandraks ... I found this online today. Could I impose upon you to verify this is what you were thinking? https://www.cokertire.com/tires/700-14-bf-goodrich-1-whitewall-tire.html
Of course my hub caps will be the VW chrome types like this or something similar https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113601151WW
Thank you
-Mark
PostPosted: Tue Apr 20, 2021 6:05 pm    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
I had those tires on my old '64 13-Window if you want to see what they look like
markeaton
PostPosted: Wed Apr 21, 2021 4:22 am    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Thank you Everett... that helps.
mandraks
mandraks is offline
PostPosted: Wed Apr 21, 2021 11:37 am    Post subject: Re: Quick question - 1966 deluxe tire Reply with quote
Thank you
-Mark
yes, that would be the right size. Only thing i see is that it is a 4ply tire, and 6ply would be better if you plan on using it "heavily". a 6ply would be a little stiffer, and it would handle more weight than the 4plys.
Maybe Everett can chime in with how his tires rode.
regards
Uli
