Ksmit258 Samba Member
Posted: Mon Apr 19, 2021 1:59 pm Post subject: Adjusting idf 40 carburetors |
So I’m adjusting carburetors...i followed this redline procedure I read.
Turned idle screw 1/4 after touch rough as hell but stayed running..adjusted 2 idle mixture screws on one side until running good....other side (left) I can turn all the way in and no change...so I backed 2 turns and was going to close other side all the way after I recorded turns.
Soon as I turn all the way in would die....it’s like the one side idle mixture screws are doing anything...same jets, float height both cleaned the same and same idle jets on both side.....any help...I might need to describe better also
But it’s getting there...no more gas in oil... diaphragm on fuel pump bad.
Oil/fuel coming out of exhaust...resolved all new ignition parts and re set timing and valve clearance.
By the way compression check
96- on 1
99.5 on 2
99 on 4
102 on 3 |
L5wolvesf Samba Member
Joined: August 17, 2009 Posts: 196 Location: Northern AZ
Posted: Mon Apr 19, 2021 4:10 pm Post subject: Re: Adjusting idf 40 carburetors |
Were the carbs THROUGHLY cleaned, now kinda sorta but THROUGHLY cleaned, before you installed them?
Also, are the jets virgin (a.k.a. not drilled out)? _________________ Amonster Motorsports
SNORE # 1196 sponsored by:
- www.356carburetorrescue.com/home.html
- Barnwerks Fabrication & Welding
- ArtSpeed Graphics
“Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting.”
S. McQueen |
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Mon Apr 19, 2021 6:07 pm Post subject: Re: Adjusting idf 40 carburetors |
ALSO , it is imperative to disconnect the throttle linkages. If not, you’ll never get it right. When you hook it back up, they MUST open at exactly the same time or it will cause all sorts of issues like vibrations and such. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Posted: Tue Apr 20, 2021 1:27 am Post subject: Re: Adjusting idf 40 carburetors |
Yes to cleaned...I spent over a weak a very thorough cleaning and they are brand new 115 jets I installed...
And thanks I did not know you should do it without the linkage.
They is great idea I will try next...
Thanks all for the input!!! |
ekacpuc Samba Member
Joined: December 08, 2010 Posts: 1414 Location: ketchikan alaska
Posted: Tue Apr 20, 2021 1:39 am Post subject: Re: Adjusting idf 40 carburetors |
Ksmit258 wrote: |
You're using a sync tool right? Snail gauge or something?
https://www.youtube.com/watch?v=RulfLVoRtZ4
It sounds to me like you're not. If they aren't synced the mix wont work on the side that is pulling less vacuum.
To get them to idle sure count your turns and start off a little higher than you want so that the motor will idle and use the snail gauge to adjust them the same.
Also curious if the compression check was done @ WOT. Seems low to me. |
Posted: Tue Apr 20, 2021 8:11 am Post subject: Re: Adjusting idf 40 carburetors |
Yes WOT when compression checked...yes not perfect but not low enough to dive into motor over summer...be a winter project next year. I’m in Michigan!! |
oprn Samba Member
Joined: November 13, 2016 Posts: 12735 Location: Western Canada
Posted: Wed Apr 21, 2021 4:48 am Post subject: Re: Adjusting idf 40 carburetors |
Compression may be a bit low but it is fairly even. That to me is most important. The original compression ratio of the engine and the altitude you are at play a big part in how high those numbers are. I once had a 36 hp engine that had 75 psi all around and it ran fine. In fact it was still running good 2 years later when a co-worker bought it from the couple I sold it to. I judge the need to rebuild more by oil consumption than by how high the compression numbers are. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Wed Apr 21, 2021 4:19 pm Post subject: Re: Adjusting idf 40 carburetors |
This project is getting better and better...very happy how it’s going.
So my next question is I ordered this snail tool for synchronization.
What number is the bogey...or any and all advice will be great full
IE: set both and front and rear barrels same,
Engine at full temperature?
Use idle mixture to get numbers?? |
Posted: Wed Apr 21, 2021 6:40 pm Post subject: Re: Adjusting idf 40 carburetors |
Ksmit258 wrote: |
Number isn't so important just want the carbs the same. It's adjustable by throttle adjustment. Mix won't change it. To get the barrels close on the same carb you use the bypass. I've only had to do it on one set. The barrels should be close on same carb but it isn't as important as between the two carbs is
Watch the video I posted. |
