orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Mon Apr 19, 2021 5:05 pm Post subject: Best way to deburr endplay shims? |
Sorry for the stupid question. Just haven’t been able to find any info.
Thanks |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Mon Apr 19, 2021 6:04 pm Post subject: Re: Best way to deburr endplay shims? |
Very carefully. You don't want to bend them at all. Perhaps a fine sanding roll?
I would get different ones... _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Posted: Mon Apr 19, 2021 6:38 pm Post subject: Re: Best way to deburr endplay shims? |
evanfrucht wrote: |
I would get different ones... |
Thanks. Or maybe a fine needle file? It’s for a type 4. I don’t know if there is much of a selection around in terms of quality. I don’t think they are necessary bad. |
raygreenwood Samba Member
Posted: Mon Apr 19, 2021 7:47 pm Post subject: Re: Best way to deburr endplay shims? |
orwell84 wrote: |
evanfrucht wrote: |
A thick piece of glass or granite with a hard smooth block with 1000 grit or finer....but moving up to 2000 or better to put a polish on them ....is how I have done a few of these.
If these burrs are "kinks" on the edge...they are done. If they are rust spots/specs....they may be done if the pit they leave is deep enough. Ray |
Posted: Mon Apr 19, 2021 8:11 pm Post subject: Re: Best way to deburr endplay shims? |
Thanks. They are new. Just a little sharp around the edges |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Mon Apr 19, 2021 8:16 pm Post subject: Re: Best way to deburr endplay shims? |
I use a diamond sharpening "stone". _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Mon Apr 19, 2021 10:46 pm Post subject: Re: Best way to deburr endplay shims? |
Possibly same as lapping a piston ring but much smaller, would be best, but too much work.
something that thin just has sharp edges by nature IMO, but it's arguable.
If the edges are raised up might have to fix that.
Sometimes what works nice is get a soft rubber "craytex" wheel, and let it wear a groove in the wheel. Works for threads. |
Posted: Tue Apr 20, 2021 5:24 am Post subject: Re: Best way to deburr endplay shims? |
modok wrote: |
Thank you. Yes, it has some raised edges. Nothing crazy, but the typical burrs you might find here and there on cylinder base shims, etc. Kind of like a lot of aftermarket parts that seem to require a little cleaning up.
Probably overthinking it, but I used to not pay attention to any of this stuff. |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Apr 20, 2021 5:44 am Post subject: Re: Best way to deburr endplay shims? |
Knife sharpening stone...
Or a diamond file. |
