1.9l td turbo help
Stacks81
Stacks81 is offline
PostPosted: Mon Apr 19, 2021 5:21 pm    Post subject: 1.9l td turbo help Reply with quote
Looking for a replacement turbo which is go longer good for my 1.9l td.
Part numbers on the turbo are 028145703B 465577-1 VL5399F
Having trouble finding one on the internet. Exhaust manifold has a trapezoidal shape to it where the turbo mounts to.
Any info will be a big help.
Pics to follow.
Stacks81
Stacks81 is offline
PostPosted: Mon Apr 19, 2021 5:24 pm    Post subject: Re: 1.9l td turbo help Reply with quote
RolandD
RolandD is offline
PostPosted: Mon Apr 19, 2021 8:05 pm    Post subject: Re: 1.9l td turbo help Reply with quote
Most diesel injection pump repair shops can repair turbos, or at least find you a new center section. What is wrong with it?
Roland
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Apr 20, 2021 12:25 am    Post subject: Re: 1.9l td turbo help Reply with quote
Look up Turbo Rebuild.co.uk, I bought a brand new full Borg Warner unit a couple years ago from them, they ship in 3 days for super cheap to the US, I dunno how they do it.
Team WorldTour
Team WorldTour is offline
PostPosted: Tue Apr 20, 2021 4:14 am    Post subject: Re: 1.9l td turbo help Reply with quote
Do a part number search on eBay. Eastern Europe is on the forefront of turbo rehabilitation. The 1.9 AAZ is the Small Block V8 of Europe.
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Stacks81
Stacks81 is offline
PostPosted: Tue Apr 20, 2021 4:39 am    Post subject: Re: 1.9l td turbo help Reply with quote
Roland
The center section is all loose I had a guy look at it. Said to just get a new one. Leaking oil as well.
Stacks81
Stacks81 is offline
PostPosted: Tue Apr 20, 2021 5:05 am    Post subject: Re: 1.9l td turbo help Reply with quote
Looked found some used ones from Lithuania that’s about it.
http://www.invasionautoproducts.com/19vocartbtu4.html
Found this though just a little pricey
Stacks81
Stacks81 is offline
PostPosted: Tue Apr 20, 2021 5:06 am    Post subject: Re: 1.9l td turbo help Reply with quote
Checked didn’t have what I’m looking for
valvecovergasket
valvecovergasket is offline
PostPosted: Tue Apr 20, 2021 7:22 am    Post subject: Re: 1.9l td turbo help Reply with quote
its pretty trivial to rebuild these units, you may look into that. might take you an hour or so.
i rebuilt the little k03 on our tdi with a ~$40 or so kit from ebay. new center bushing, all the little seals and clips and whatnot.
you just have to find the kit that matches your center housing.
lots of DIY videos online as well, theyre quite simple to take apart just mark the orientation of the compressor wheel and the turbine/shaft
MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread
11BC2
11BC2 is offline
PostPosted: Tue Apr 20, 2021 2:20 pm    Post subject: Re: 1.9l td turbo help Reply with quote
Locate a compressor wheel and housing from an early/mid 80s Volvo 240 or 740 and install that on your new turbo.
Turn the boost up to about 10psi.
You'll love it.
RolandD
RolandD is offline
PostPosted: Tue Apr 20, 2021 7:53 pm    Post subject: Re: 1.9l td turbo help Reply with quote
OK, your bearings need replacement.. Did the aluminum compressor hit the aluminum housing? If not, buy new bearings and seals.
.Roland
