Heat riser tin sealing gaskets - Where do I buy?
Bug53
Bug53 is offline
PostPosted: Mon Apr 19, 2021 11:31 pm    Post subject: Heat riser tin sealing gaskets - Where do I buy? Reply with quote
Does anyone know where I can obtain the seals that insulate the tins and breast plates around the heat riser tubes?
It's listed on WW but out of stock.
Thx.
MuzzcoVW
MuzzcoVW is online now
PostPosted: Tue Apr 20, 2021 3:14 am    Post subject: Re: Heat riser tin sealing gaskets - Where do I buy? Reply with quote
M&T Manufacturing has them, it's where I got mine. https://www.mtmfg.com/part/view/fresh-air-hose-sea...rt=111-586
MuzzcoVW
PostPosted: Tue Apr 20, 2021 3:18 am    Post subject: Re: Heat riser tin sealing gaskets - Where do I buy? Reply with quote
Thx.
I just re read what you typed. They should have the heat riser gaskets also. In fact I may have some if you can't find any. I'm 99 percent sure they come in the Elring gasket sets. I have a new set for a rebuild I'm working on and my F.I. engines don't use those seals.
APPLEGREENVW
APPLEGREENVW is offline
PostPosted: Tue Apr 20, 2021 5:38 am    Post subject: Re: Heat riser tin sealing gaskets - Where do I buy? Reply with quote
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D119%2D597
Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan
