45-70bpcr Samba Member
Joined: November 12, 2004 Posts: 67 Location: N.W. PA
Posted: Tue Apr 20, 2021 9:55 am Post subject: Fixed odometer (I think) but now no turn signals? (SOLVED) |
Stuck home with the covid crap and not too with it so hoping I am missing something obvious. Pulled the instrument cluster out and apart to put a new odometer gear in. That went great. Now that it is back together my turn signals took a crap. The indicator light comes on, usually stays solid but no signals come on. Once in awhile they will come on and flash very slowly. Seems like a bad ground but??
I put a new flasher in a year or so ago. Not sure if I created the problem or if just coincidental and my flasher went bad? I had all the wires off the lights but I would think the worst that could happen there is getting the lights in the wrong hole. Any thoughts would be appreciated.
busdaddy Samba Member
Posted: Tue Apr 20, 2021 12:18 pm Post subject: Re: Fixed odometer (I think) but now no turn signals? |
I'd be looking for a wire that got knocked off the hazard switch or fuse box during the cluster wrestling to start with. Also how well charged is your battery? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Tue Apr 20, 2021 9:17 pm Post subject: Re: Fixed odometer (I think) but now no turn signals? |
That circular cluster of brown ground wires is ground central for the front of the bus. One of the wires goes to a body ground tab up by the wiper motor, and when pulling the instrument cluster, it's easy to pull it off, which un-grounds the cluster. Check that it's connected.
A black switched 12 volt feeder wire goes to the fuel gauge regulator and to the mounting plate for a bunch of dash indicators, including the turn indicator. Make sure it has power when the key is on. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Thu Apr 22, 2021 10:50 am Post subject: Re: Fixed odometer (I think) but now no turn signals? |
Thank you very much guys for the tips. I checked all the grounds and connections again and
Wasn't getting anywhere. Sometimes they would flash very slowly usually not light at all. Flasher was only a few months old and genuine vw so I thought it unlikely it was bad. Pulled it out for giggles and stupid thing is full of water! Apparently my new windshield seal ain't doing the best job. I got the cap off the relay, used electrical contact cleaner and some wd-40. Works like a champ now. I saw in the archives someone describing this very issue with a wet flasher relay. I was sure that wasn't my issue when I read it, I have a new seal |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Thu Apr 22, 2021 1:50 pm Post subject: Re: Fixed odometer (I think) but now no turn signals? (SOLVED) |
glag you have resolution, and thanks for the closure!! |
