djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32635 Location: Reading Pennsylvania
Vanuber Samba Member
Joined: February 16, 2020 Posts: 411 Location: Virginia
Posted: Wed Apr 21, 2021 5:28 am Post subject: Re: 3rd seat rail covers |
djkeev wrote: |
If I had a sheet metal brake I could bend something up...... but alas.... I don't. |
If it was me, I would hire a machine shop to fabricate a steel part, then paint or powder coat it. But not sure how much you want to invest in this. _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
'02 Subaru Forester 2.5L |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Wed Apr 21, 2021 5:33 am Post subject: Re: 3rd seat rail covers |
You could try aluminum "U" channel.
2" x 1.25" x 0.17" x 0.26" Aluminum Channel 6061-T6-Extruded Aluminum.
They have many sizes.
https://www.onlinemetals.com/ _________________ This free advice is worth exactly what you paid for it.
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Wed Apr 21, 2021 5:34 am Post subject: Re: 3rd seat rail covers |
Seems like you could make something that would work well and look good from some hardwood flooring. Trim and plane to fit flush and tight, kind of countersink some mounting bolts. I can't remember if those are weld nuts or not that the bolts attach too, but either way you could just run some slightly longer bolts.
Just spit balling, fun project! _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Wed Apr 21, 2021 5:36 am Post subject: Re: 3rd seat rail covers |
Or steel u channel:
https://www.industrialmetalsupply.com/shop-metal-by-shape _________________ This free advice is worth exactly what you paid for it.
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Wed Apr 21, 2021 5:41 am Post subject: Re: 3rd seat rail covers |
Contact vwcultmember. He seems to have the most bits and parts for the middle seats.
I took photos of my rail covers if they are of possible use to you. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
Posted: Wed Apr 21, 2021 6:21 am Post subject: Re: 3rd seat rail covers |
Photos of metal covers:
Hope it helps!
I like your idea of just flooring over it..... _________________ ________________________________________
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
DuncanS Samba Member
Posted: Wed Apr 21, 2021 11:10 am Post subject: Re: 3rd seat rail covers |
This attachment method has always bugged me. The gap in whatever the flooring is has to go all way to the door sill. If you keep the aluminum sill plate that has to come out, then the carpet or rubber, then the cork stuff before the seat can be slid out. Since there are blind nuts already there to hold the rails on, why not pull these and throw them overboard. Drill the matching rail part on the seat and bolt it down using the OG blind nuts. I don't see anything different in safety as the same number of bolts will get used in either case. This way you can fill the missing cork area and simply have a small hole in the carpet/mat/flooring for the bolts. I never plan to put mine back in in that location, so I cut some bolts and slotted them and used them with LocTite to fill the hole so water wouldn't come in. You could use socket allen bolts for the same purpose and have it easy to take them out when you want to put the seat back in.
Duncan |
danfromsyr Samba Member
Posted: Wed Apr 21, 2021 1:54 pm Post subject: Re: 3rd seat rail covers |
Dave just an FYI, iirc the metal covers are only for the WESTY and not offered in the tintop 7 passenger configuration.
meaning that the metal covers won't cover the tracks the full width across the floor of the van.
the westy covers were also segmented in a fashion that allowed the track to be covered either with the seat installed or removed. ie. they're a bunch of short little buggers.
the tintops just covered the tracks with the carpet flaps.
I'd suggest a openbox of Pergo type flooring.. click it together but not installed permanently can usually do that for $10bux. so it's fairly sacrificial in nature. _________________
Abscate wrote: |
