Junkyardjockey Samba Member
Posted: Wed Apr 21, 2021 8:36 am Post subject: For those that have used 1.25 rocker arms on stock width engine |
I really would like to know what your pushrod measurement came out to be, because the stock length pushrods are not going to work! I would really appreciate an honest answer; not any snide remarks. If you need the specs on the cam I have, here they are:
Adv. Duration 274°
Dur. @ .050" 224°
Lift @ cam .357"
Lift w/1.1:1 Rocker Arms .393"
It would be greatly appreciated if you made a note of this somewhere when you built your engine; that would help immensely! If you need any other specs on my build, please let me know. I'm just hoping that someone else uses these same rocker arms & wrote it all down. Thanks in advance! _________________ Romans 10:9-10
SAVE THE SUPERS!!
1974 Super Beetle Sunroof
2022 Subaru Outback Limited XT in crystal white pearl
2022 Subaru Outback Limited XT in cinnamon brown pearl |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Wed Apr 21, 2021 9:13 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
All engines are different. With different fly cut heads, cylinder length etc. Youll need a n adjustable push rod to get an idea of the length of rod needed. |
Posted: Wed Apr 21, 2021 9:30 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
GARRICK.CLARK wrote: |
I just ordered Gene Berg's adj pushrod tool. This one seems to be the best available. Part # GB 420. While it requires me to take off one head & pushrod tube to make the adjustments, I feel this is the way to go. Thank you sir for your reply! _________________ Romans 10:9-10
SAVE THE SUPERS!!
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
It is impossible to know what your length will be.
I could build the same engine with the same cam, and I might end up with a different length. Way to many different heads, cylinders, flycut depths, etc...
Only way to do it correctly is to mock it all up, learn how to do the geometry and measure YOUR engine with YOUR parts.
Brian _________________ www.type-emotorsports.com |
Posted: Wed Apr 21, 2021 9:31 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
BTW sir the gentleman who answered the phone at Gene Berg is from the south of London! Cheers! _________________ Romans 10:9-10
SAVE THE SUPERS!!
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Wed Apr 21, 2021 9:42 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
That looks to be a 2280 cam (could be wrong though.)
But, if everything is stock apart from the cam, you should be able to get decent valve train geometry by simply adding 0,030 or 0,060" shims under the rocker arms. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Wed Apr 21, 2021 10:31 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
Alstrup wrote: |
But, if everything is stock apart from the cam, you should be able to get decent valve train geometry by simply adding 0,030 or 0,060" shims under the rocker arms. |
the cam is CB's 2228 sir. _________________ Romans 10:9-10
SAVE THE SUPERS!!
modok Samba Member
Posted: Wed Apr 21, 2021 10:32 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
Junkyardjockey wrote: |
not any snide remarks. ..................................I'm just hoping that someone else uses these same rocker arms & wrote it all down. Thanks in advance! |
But you didn't say what kind of rockers you have
ANd nobody else asked?
I can't think of much alternative to snide remarks bud, you guys are all begging for it.
Best I can do is try to have a sense of humor. |
Posted: Wed Apr 21, 2021 10:36 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
modok wrote: |
I DID mention I have 1.25 rockers; unless you mean where I got them from. In that case, CB Perf. _________________ Romans 10:9-10
SAVE THE SUPERS!!
Posted: Wed Apr 21, 2021 10:37 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
Modok has a point I assumed you have VW style 1,25 rockers.
The 2228 will not change anything in that direction over the 2280. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Apr 21, 2021 11:15 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
modok wrote: |
I DID mention I have 1.25 rockers; unless you mean where I got them from. In that case, CB Perf. |
They make 2 different styles of 1.25 rockers and they each use different length push rods.
You have rockers with the adjuster on the valve side and rockers with the adjuster on the push rod side.
To add more factors you also have needle bearing rockers and roller tip rockers. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed Apr 21, 2021 11:17 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
vwracerdave wrote: |
modok wrote: |
You have rockers with the adjuster on the valve side and rockers with the adjuster on the push rod side. |
ok thanks sir! mine have the adjusters on the valve side. I have never seen them on the pushrod side. _________________ Romans 10:9-10
SAVE THE SUPERS!!
Posted: Wed Apr 21, 2021 11:34 am Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
You want the closed valve rocker angle at TDC to look like the full lift rocker angle. Half lift makes the valve and the valve adjusting screw look like a straight line.
At full lift.. check if the push rods are touching the push rod tubes. Check all 8.
Check the contact point of the tappet adjusting screw, (swivel feet/elephants foot or similar) against the valve tip. Paint some Stuarts Blue on the valve stem tips, the contact point will wipe some of the blue off the valve tip. This needs to be right along with the geometry. |
modok Samba Member
Posted: Wed Apr 21, 2021 5:25 pm Post subject: Re: For those that have used 1.25 rocker arms on stock width engine |
I see currently CB sells only one kind of rocker with that ratio, at the moment, but in the past they have sold many kinds
These right? https://www.cbperformance.com/product-p/1692.htm
I have used these side by side with stock rocker arms.
They can use the same pushrod length if "all else" is the same.
So you must have some different parts in your all else than before. |
