Krumby Samba Member
Posted: Wed Apr 21, 2021 10:07 am Post subject: Anybody put a bigger alternator on their 84 Westy? |
Aloha
I have a 84 westy with a 1.9 motor with a aux battery hooked up to a go westy isolator The newer one. I was thinking of maybe of getting a bigger alternator to charge the aux battery maybe a little faster when driving. I have a powered cooler and would like a faster way to keep the battery topped off. I have a deep cycle gel battery that is pretty powerful. Just looking for options before i go solar.
Leads on where to get a bigger alternator?
Mahalo for the help _________________ 84 Westy “Betty”
71 bus gone but not forgotten
2015 Harley dyna |
CansoJim Samba Member
Joined: January 21, 2013 Posts: 40 Location: Canso, Nova Scotia
Posted: Wed Apr 21, 2021 4:11 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
Hi,
I got mine at quality power. Had it for several years now. No issues. You will need to upgrade your wiring.
https://www.qualitypowerauto.com/item_447/VW-Vanagon.htm
Hope this is helpful.
Jim. _________________ 89 Canadian PreRunner Westy GL JOVH 2.3 Auto w/ Peloquin TBD |
Krumby Samba Member
Posted: Wed Apr 21, 2021 5:13 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
What wiring what would I have to change ?
Mahalo
David _________________ 84 Westy “Betty”
2015 Harley dyna |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Wed Apr 21, 2021 6:05 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
Are you using the gowesty relay and your own system or the whole gowesty charging kit?
If you're using the whole kit, when I switched to an automatic control relay and heavier gauge wiring, I gained about .5 volts of charging power. That's a lot relatively and probably a better investment than a bigger alternator. I'm far from an electronics wizard, just my opinion. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Squidfish Samba Member
Posted: Wed Apr 21, 2021 6:35 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
I am happy with the 28mm internal adjustable voltage regulator I put in recently. I am charging at 14.2 volts now. Less than $40 shipped and 5 minutes to put in.
https://www.prancingmoose.com/AdjustableVoltage.html#vw
Check and clean/replace grounds first and consider replacing your alternator cables; there is a lot of resistance in 30+ year cables no doubt. _________________ 1985.5 - Vanagon Westfalia Weekender Wolfsburg Edition - LH8U - "Penny"
- 2.6i 5-Cylinder 10v (2004) |
Posted: Wed Apr 21, 2021 6:39 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
Hi,
It’s the wire from the starter to the alternator. GoWesty sells an alternator harness upgrade kit. As usual, GoWesty supples lots of information:
https://www.gowesty.com/product/-/23762/alternator-wiring-harness-upgrade-kit-?v=
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Wed Apr 21, 2021 7:05 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
Make your own and make it bigger. _________________ This free advice is worth exactly what you paid for it.
Krumby Samba Member
Posted: Wed Apr 21, 2021 9:38 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
I have the go westy alt harness already installed put it in a while ago. I’m just looking for a way to maybe charge my six battery faster. I live on a small island so distant driving is not a way to charge.
Mahalo
2015 Harley dyna |
Krumby Samba Member
Posted: Thu Apr 22, 2021 12:52 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
I like that idea of the dc to dc charger I may try that
Mahalo you guys always come through when I need something. _________________ 84 Westy “Betty”
2015 Harley dyna |
Krumby Samba Member
Posted: Thu Apr 22, 2021 12:53 pm Post subject: Re: Anybody put a bigger alternator on their 84 Westy? |
2015 Harley dyna |
Krumby Samba Member
2015 Harley dyna |
