shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Wed Apr 21, 2021 9:56 pm Post subject: Trip odometer stuck at 0.9 but odometer works fine. How to fix? |
The title pretty much says it all. Speedo, odometer, and trip odometer all worked fine until recently the trip odometer got stuck at 0.9. I've reset the trip odo, and it does the same thing - the tenths of mile roll fine up to 0.9 and then it stops. I've searched around and haven't found this exact situation but am wondering if anyone's had this happen and if they've been able to fix it. _________________ 1989 Bostig Syncro Westy |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Wed Apr 21, 2021 10:57 pm Post subject: Re: Trip odometer stuck at 0.9 but odometer works fine. How to fix? |
Fixing it correctly is simple, Take it out and put it in a box and send it To Palo Alto Speedometer. They will rebuild it and not just fix one of the issues through some Mickey Mouse hack.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
DuncanS Samba Member
Posted: Thu Apr 22, 2021 7:51 am Post subject: Re: Trip odometer stuck at 0.9 but odometer works fine. How to fix? |
When they stick, it's always at one or some of the 9s as it taks more torque to move the next cylinder from 0 to 1. A gear is slipping on the shaft. Sooner or later it happens to all VW odometers. |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Thu Apr 22, 2021 5:40 pm Post subject: Re: Trip odometer stuck at 0.9 but odometer works fine. How to fix? |
If you already work on your van this is not a huge challenge. The instrument cluster is pretty easy to remove and the repair is not difficult once you know what to do. Many of us have done this.
You'll wind up pulling one of the shafts out far enough to knurl the end, and when you reinstall everything the slipping gear will be on the knurled section.
Not the shaft in the photo but the one for the odo gears.
_________________ '87 Westy in Wolfram Grey Metallic |
