Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Sat Apr 24, 2021 3:23 am Post subject: Re: Getting a Type 4 engine to start after 10 years |
Mice less important. More important to get fresh gas in, old gas out, and. Getting the oil water slurry out of the crankcase before starting.
It’s not going to run well, that carb will be completely gunked up.
The price on turning the key to “ see if it will start” could be 4-8k , otherwise _________________ .ssS! |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1881 Location: N.W. Georgia
Posted: Sat Apr 24, 2021 5:06 am Post subject: Re: Getting a Type 4 engine to start after 10 years |
You will smell the mouse nesting if and when your engine starts, it’s a foul burnt mulch/hot urine smell. It kind of smells like money burning. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Sat Apr 24, 2021 7:28 am Post subject: Re: Getting a Type 4 engine to start after 10 years |
Abscate wrote: |
The price on turning the key to “ see if it will start” could be 4-8k , otherwise |
The above is true. Drain the gas tank, new fuel lines, and new fuel filter.
If you have extra time, maybe pour 2-3 gallons of diesel in the fuel tank, rock the bus back and forth and then, drain the gas tank to remove any rusty bits. Then pour new 2-5 gals of gas in the tank, rinse and repeat with gas. The goal here is to see if the tank is rusty and clear any nasty rust outta the tank. You'll find out real quick if the tank is blocked. _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Sat Apr 24, 2021 9:50 am Post subject: Re: Getting a Type 4 engine to start after 10 years |
If the tank has been sitting with a load of ethanol laced fuel in it, its going to take more than swishing the tank out with fresh fuel to make it serviceable. The tank likely has a layer of goo inside that will slowly dissolve and move through the fuel system clogging jets and causing sticky valves for tens of thousands of miles to come if it is not remove somehow before the rig is put back into service.
If he wants to run it as is, the OP should buy a half dozen cases of Tectron "Ethanol" fuel system cleaner and enough cheap synthetic oil to add a pint at every fill up for the next 50K miles to keep the valves from sticking and having negative interactions with the pistons, and of course make sure he keeps his AAA towing insurance paid up. |
Jason0115 Samba Member
Joined: April 11, 2021 Posts: 97 Location: New Jersey
Posted: Wed Apr 28, 2021 6:21 pm Post subject: Re: Getting a Type 4 engine to start after 10 years |
Rider_Surfboards wrote: |
Whereabouts in NJ are you located? |
Hunterdon county, how about you? |
Posted: Wed Apr 28, 2021 6:22 pm Post subject: Re: Getting a Type 4 engine to start after 10 years |
60vwnewengland wrote: |
Pictures of OP engine
No engine bay seal, probably disintegrated over the 10 years. Center mount carb with some FI components still in engine bay. But based on these two photos, I wouldn’t turn the key to try and run it.
t |
Is their any FI components that are missing which you can notice? |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Apr 28, 2021 6:27 pm Post subject: Re: Getting a Type 4 engine to start after 10 years |
Jason0115 wrote: |
t |
I notice that it has a single progressive.....good news is he wont have to worry about vac leaks and cracks in S boot. edit-but you knew that... |
Rider_Surfboards Samba Member
Joined: April 16, 2015 Posts: 69 Location: New Jersey
Posted: Thu Apr 29, 2021 5:11 am Post subject: Re: Getting a Type 4 engine to start after 10 years |
Jason0115 wrote: |
I am in Monmouth County. I saw from your other thread that you may be passing up this bus and continuing your search for another—probably not a bad idea.
If/when you come across a good project, I may be able to come up and help you see what’s what. Shoot me a PM when that time comes.
I’ve had lots of help from the community on my own VW journey, and its been one of my favorite parts of owning one of these vehicles. I will be glad to repay the favor if I can.
— Kevin _________________ 1979 Bus Weekender -- Gertrude McBus |
Posted: Sat May 01, 2021 8:14 am Post subject: Re: Getting a Type 4 engine to start after 10 years |
I appreciate that Kevin, I'll give you a pm if I find something nearby. I'm trying to get the word out and network around. Hope I come across a good deal soon. It has been a warm welcome from the community.
I'm thinking of getting the bus in the photos for parts. Fiddle with engine learn on it since I wont be driving it. Plus, it has all the interior camping gear minus some of the fabric and the shot front seats. All for hopefully under 750. |
