Correct steering setup?
pyro273
pyro273 is offline
PostPosted: Thu Apr 22, 2021 1:58 pm    Post subject: Correct steering setup? Reply with quote
The steering shaft mount on the sand rail I am trying to update is 7/8 but the new rack and pinion is 5/8 36 spline. A 5/8 36 spline to 7/8 smooth u-joint doesn't seem to be all that common (I think I've found just one) so is that the correct way to go here?
I need about 38" of steering shaft and was just going to do two u-joints, one at the rack and pinion and one near the steering shaft mount, using a new 7/8 shaft with the 3 bolt flange for the steering wheel.
Should I be concerned with the 5/8 to 7/8 u-joint connection?
Thanks,
Pyro
21golden007
21golden007 is offline
PostPosted: Thu Apr 22, 2021 3:12 pm    Post subject: Re: Correct steering setup? Reply with quote
Maybe this is the one your're referring to, but pacific customs sells 5/8-36 to 7/8 smooth, link below. I can't imagine why'd there'd be any issue but I'll let others chime in on that. I THINK most rack&pinion setups are 5/8 or 3/4 going 3/4 or 7/8 shaft.
https://www.pacificcustoms.com/mm5/merchant.mvc?Sc...ange_high=
pyro273
pyro273 is offline
PostPosted: Thu Apr 22, 2021 4:27 pm    Post subject: Re: Correct steering setup? Reply with quote
Yep, that's only one I've been able to find vs. the plethora of 3/4 to 7/8 or 5/8 to 3/4 u-joints out there. I wouldn't be concerned if the shaft on the R&P was 3/4.
Dale M.
Dale M. is offline
PostPosted: Thu Apr 22, 2021 6:29 pm    Post subject: Re: Correct steering setup? Reply with quote
Go outside VW world, there is a ton of U joints out there, one brand is Borgeson...
http://www.borgeson.com/joints.html
https://www.summitracing.com/search/part-type/stee...AcEALw_wcB
https://www.jegs.com/p/Borgeson/Borgeson-Steering-...3sEALw_wcB
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
