Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Fri Apr 23, 2021 7:25 am Post subject: Removeable Apron |
Digging around here, wasn't able to find specifics on making a rear apron removable..
Seemed like just a matter of drilling some spot welds and pulling it off.
And it was!
This car is a total Bondo bucket, is going to be driven by a high-school kid now,
And I'm getting SO sick of struggling with a late motor in an early compartment..!
I'll already say i don't know why i never did this mod before..!
If you have a car that's never going to be original again anyways like mine,
Do it.
Basically, you can make it so the two rear fender bolts at the beading pinch the apron into place.
Decided to weld up all of my drill holes, but you wouldn't even have to do that if you didn't want to.
Did the same for the car itself, fixed a stripped fender bolt, pklus welded in another to make the filter hanger as easy on/off vs. the two-wrench struggle it always was..
Once the hackery has been cleaned up and smoothed out, the apron can just slide into place.
A couple more holes to weld shut, and some paint touch-up, then the repair should be invisible from the outside of the car.
The only issue (and a question to any that have gone before),
Is how to deal with these two flappy bits on the inside of the compartment?
They have to be bent out of the way a little bit in order for the apron to slide on/off.
Thinking I'll just trim them down maybe an inch or so?
Maybe?
Anyone have some slick way to prevent having to bend things or chip the paint with every on/off?
Looking at the pics again, I'd love to get some seal channel and carb windows from Danny Gabbard and keep going with this project,
Especially since the paint gun is coming out,
But,
Like always,
This thing needs to go back together ASAP so it can be driven around and not just sit here in the way forever..! _________________ Bus Motor Build
What’s That Noise?!? |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Fri Apr 23, 2021 12:33 pm Post subject: Re: Removeable Apron |
To be fair, you just need to keep triming the excess metal neatly until it fits.
The valance metal with the drill holes that fits inside the engine bay on both sides needs to come off |
veltror Samba Member
Don Jones Samba Member
Joined: April 09, 2020 Posts: 199 Location: Makaha, Hawaii
Posted: Fri Apr 30, 2021 10:51 am Post subject: Re: Removeable Apron |
When i did my removable apron, i bought a new one from CIP1 (Cal Look) without the exhaust notches.
I didn't want any screws / bolts in the engine bay so i put a rivet nut and s/s screw right where you have the rubber seal removed to hold down the top portion of the apron. This and the 2 fender bolts on both sides are enough to hold the apron in place.
For the lid seal, i bought the mexican lid seal from cip1. This seal attaches to the deck lid (slides on the lip). This is the way it should have always been. I removed the seal lip metal from the car as this is where rust starts.
When removing my apron i remove the fender bolts and (2) hold down screws and shift the apron up and angle the right side higher and right out.
I installed the danny gabbard weber windows also...used his aircraft rivets (wish they were a little longer), but it works. It's real good quality. |
