tristanblue Samba Member
Posted: Fri Apr 23, 2021 11:45 am Post subject: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
Thanks |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Posted: Fri Apr 23, 2021 6:19 pm Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
Isn't stacking shims kinda sketchy to do?
Always been advised against that especially large amount like .1"
Maybe not?
T |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Fri Apr 23, 2021 8:57 pm Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
It would be ideal to have the exact size spacer you need but more often than not stacking is the way to dial in your deck height.
Its not an issue, just make sure the size is consistent all the way around and burr the edges.
Then torque them down with the cylinders to confirm it's all good.
I like to used a plate that covers both cylinders.
RWK Samba Member
Posted: Sun Apr 25, 2021 7:33 am Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
I can build you a custom set, PM me. These were .15 thick
_________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
mark tucker Samba Member
Posted: Sun Apr 25, 2021 11:04 am Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
either stack or pay.either way.the cylinder is stacked on them and the head is stacked on that...unless you have a head gasket stacked between...I wood do a .060&.040" or 2 , 50's... 2 50's might be eazer so you dont have to keep track and end up with 2 40's &2 60's on a hole or 2 I do like the machined shims better....but not always$ or time to do it. |
Posted: Sun Apr 25, 2021 5:35 pm Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
RWK wrote: |
I can build you a custom set, PM me. These were .15 thick |
Thank you RWK will do! |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Mon May 03, 2021 1:42 pm Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
I had considered those but extending the stroke by .0984 on each side and thus the compression ratio as well, I would rather play on the safe side and go .1 shims. In fact I have heard some guys even going .11 or more depending on what their actual deck height is when engine is mocked up.
I am picking up my heads and case today, will be doing mock up this week to see what shims I should use but my guess would be .1 to .11 and will be contacting RWK for a custom set for this specific engine. |
Posted: Mon May 03, 2021 1:55 pm Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
You can’t guess on deck height. I think we were all under the impression that you had already determined what shims you need. Get that all figured out, cc your heads, then order your shims based on what compression ratio you want to be at. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon May 03, 2021 7:05 pm Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
Buy a piece of this and find a shop with a waterjet machine...
https://www.onlinemetals.com/en/buy/carbon-steel/0.../pid/20183
Try to make friends with to get cost down, if I was still running the one I ran I would make you a killer deal on a set, I used to make them for 36hp guys all the time.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Tue May 04, 2021 12:44 am Post subject: Re: Who sells .1" barrel shims for 40HP 69mm stroker buillds? |
So what do some folks on here just skip over most of the posts??
Again, I am going to have RKW make custom shims when I 100% verify the deck. Stroking the engine from 64mm to 69mm is 5mm difference or 2.5mm per side or .0984", hence the "looking for .1" shim post". As I said before I will be double checking my deck FIRST but good bet it will need .1" shims. |
