danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Thu May 06, 2021 8:38 pm Post subject: Re: Chinese Diesel Heater Questions |
it's worse when you get some on your hands.. which one invariably will do..
then your nose will itch and you'll rub your eye.. very much to your own dismay..
and women can smell diesel odor half a mile away.. so will definitely overpower the romantic powers of patchouli and Barry white
solid reasons to #1 wear gloves when handling diesel/Kero fuels.
and #2 take care of refueling business OUTSIDE and when the She is away..
I'm not fond of diesel.. but the economy of the heater is worth the risks. _________________
Abscate wrote: |
scubasteve321 Samba Member
Posted: Thu May 06, 2021 10:40 pm Post subject: Re: Chinese Diesel Heater Questions |
you guys crack me up sometimes
put the fuel tank in the opposite area where your battery goes in the engine compartment
simple to fuel up, no stress about spills
simple as _________________ 1971 Campmobile Tin-Top
1971 Campmobile Pop-Top
1974 VW Bus |
cmonSTART Samba Member
Posted: Fri May 07, 2021 8:34 am Post subject: Re: Chinese Diesel Heater Questions |
danfromsyr wrote: |
and women can smell diesel odor half a mile away.. so will definitely overpower the romantic powers of patchouli and Barry white |
Ya, my wife would get out and walk home if I smelled like diesel..... _________________ '78 Bus 2.0FI
de K1IGS |
dr8track Samba Member
Joined: July 18, 2005 Posts: 501 Location: Seattle area
Posted: Fri May 07, 2021 1:30 pm Post subject: Re: Chinese Diesel Heater Questions |
While I'd love to mount the tank outside, I have a Westfalia. In the engine compartment opposite my battery is another battery. The battery takes up all the room on the far driver side. You might be able to slip a thin tank between the battery and the engine tin... maybe. I do agree with what you're saying about the potential stink factor and wifes. My wife has a nose like a blood hound.
I have seen several videos where they have mounted them inside. Not saying it's a great idea, but I think I'm still going to try there first, see how it goes and if the smell becomes an issue I'll look for a small tank for the engine compartment. _________________ 1974 Westfalia Deluxe Campmobiles - Lake Stevens, WA |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3285 Location: Rapid City, SD
Posted: Fri May 07, 2021 3:46 pm Post subject: Re: Chinese Diesel Heater Questions |
I have been using only this in my heater for 2 years now. Works great, doesn't smell like diesel fuel, and it is better for the heater if it will not be running all night. The diesel supposedly starts to soot up if it doesn't run for long periods. It is a little more expensive, but it is very easy. Most Home Depot, Ace, type places carry it.
I have a heater in my single cab, and I use it around town, so it is on/off frequently.
I also use a smaller cube shaped universal coolant overflow bottle for my tank. It is still plenty big to run all night, and could be mounted in the engine compartment even with two batteries and dual carbs.
Brian _________________ www.type-emotorsports.com |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
Posted: Fri May 07, 2021 4:16 pm Post subject: Re: Chinese Diesel Heater Questions |
I actually have cut down my samba time brother. After being a member as long as we have, its al the same, al the same, all the same,,,,,,,........ _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Sun May 09, 2021 6:48 pm Post subject: Re: Chinese Diesel Heater Questions |
dr8track wrote: |
I have seen several videos where they have mounted them inside. Not saying it's a great idea, but I think I'm still going to try there first, see how it goes and if the smell becomes an issue I'll look for a small tank for the engine compartment. |
I turned an old vanagon propane tank into a diesel tank for my heater. Works great. _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
Posted: Mon May 10, 2021 8:54 am Post subject: Re: Chinese Diesel Heater Questions |
Why not relocate your aux battery to underneath your drivers seat then?
Don't forget to run larger wire if necessary due to extra distance electricity must travel
Then you have room for your fuel tank again
Problem solved. _________________ 1971 Campmobile Tin-Top
1974 VW Bus |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Thu Sep 22, 2022 5:25 pm Post subject: Re: Chinese Diesel Heater Questions |
has anyone tied this into the buses heater tubes underneath? id love to actually be able to defrost! _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
