Czar1500 Samba Member
Posted: Sat Apr 24, 2021 5:04 pm Post subject: Exhaust leak or normal? |
This looks like an exhaust leak to me but not entirely sure?
I get a subtle pop/backfire when deaccelerating while still in gear. Wondering if that is related or if it’s normal as well?
Thanks for the wealth of information. I don’t think I would be able to keep this car running without you guys!
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Sat Apr 24, 2021 5:31 pm Post subject: Re: Exhaust leak or normal? |
You are missing a clamp/seal where the sheet metal jacket meets the exhaust pipe. They seem to be NLA, so here is a workaround:
New seals are somewhat known for not sealing well. And the leak will force exhaust gases into your heat exchanger fresh air supply. Pressure from the exhaust leak "jet" is greater than air pressure in the heater system, and it shoots it right into the heater air flow, a CO danger. Plus it stinks.
I used a non-hardening muffler sealant on the HE pipe to bridge the gaps between the rough HE pipe and the donut seal. Smooth it on, and put an excess so the donut squishes into it even without the clamp, then clamp as usual (and clean up the excess). With the goop, you don't have to crank the claps so tightly that it bends the plate and leaks.
I also took Jim Adney's suggestion to make strips of folded aluminum foil into a wrap around the HE pipe where it meets the HE metal jacket, which is where the exhaust leaks can force their way into the heater. The original clamps go here, but mine were missing:
I held them in place with a large worm clamp. No more fumes!
Posted: Sat Apr 24, 2021 6:42 pm Post subject: Re: Exhaust leak or normal? |
I’ll give that a try. Thanks for the detailed write up. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
KTPhil Samba Member
Posted: Sat May 01, 2021 1:33 pm Post subject: Re: Exhaust leak or normal? |
It runs hot at high rpm oin the freeway, not so bad around town. I'm still sleuthing the highway heat gremlins, and when all done, I may either make a sheet metal shield or look for some wrap. Bigger fish to fry right now! |
