Brake pedal doesn't return enough
ELFRIED
ELFRIED is offline
PostPosted: Sun Apr 25, 2021 7:03 am    Post subject: Brake pedal doesn't return enough Reply with quote
Certainly no binding between the pedals.
Spring correct mounted,but perhaps faulty???How to check?
Other possible reason?
Any help welcome...
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Sun Apr 25, 2021 2:47 pm    Post subject: Re: Brake pedal doesn't return enough Reply with quote
As long as the you have the correct free play in the pedal and the brakes don’t drag once everything gets hot, don’t worry about it. None of my pedals line up to the other ones but I get full throttle, the car stops and the clutch works great.
I have a new aftermarket pedal assembly which I won’t advertise cause it ain’t worth what they’re selling it for. I’ve seen images of other peoples pedals that line up perfectly though but I don’t think it’s worth the effort.
If you don’t have enough travel for your brakes you may want to adjust the pedal stop bracket on the floor pan and see if that helps.
Volkswagen!
(Compression 8.7:1)
runamoc Premium Member
runamoc is offline
PostPosted: Tue Apr 27, 2021 7:37 am    Post subject: Re: Brake pedal doesn't return enough Reply with quote
yours might be bent or crooked. It's only sheet metal
Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
simon varley
simon varley is offline
PostPosted: Thu Apr 29, 2021 4:07 am    Post subject: Re: Brake pedal doesn't return enough Reply with quote
the spring on mine is really strong, are you sure it's installed correctly?
ELFRIED
ELFRIED is offline
PostPosted: Fri Apr 30, 2021 9:03 am    Post subject: Re: Brake pedal doesn't return enough Reply with quote
Yes I am but I really think the spring is too old ,can't see another reason...
runamoc is offline
PostPosted: Fri Apr 30, 2021 9:43 am    Post subject: Re: Brake pedal doesn't return enough Reply with quote
On the LHD cars the bent tang of the return spring goes over the bolt head that holds the assembly on the tunnel. Do they make a different spring for RHD?
ELFRIED
ELFRIED is offline
PostPosted: Sat May 08, 2021 6:12 am    Post subject: Re: Brake pedal doesn't return enough Reply with quote
New spring mounted.
Pedals all nice in line and brake pedal returns immediatly.
Problem solved,thanks all.
bnam
bnam is offline
PostPosted: Sat May 08, 2021 9:47 am    Post subject: Re: Brake pedal doesn't return enough Reply with quote
Yes they do.
Click to view image
1952 Citroen TA 11BL
