TFB777 Samba Member
Joined: February 12, 2021 Posts: 35 Location: Camas, Washington
Posted: Fri Dec 17, 2021 10:23 am Post subject: Re: EV-RODENT-SHIELD |
orbeamike wrote: |
Initially I was just trying to remove the bumper cover on my 2001, later I realized it's much easier just to remove the entire bumper which was held to the frame with 4 bolts and couple trim screws. |
LOL! Twice I have done the rear bumpers the "hard" way - never even thought there might be another method to remove them! This is brilliant: KISS wins again! |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2535 Location: Ocean Beach in Beautiful BLUE California
Posted: Sat Jul 03, 2021 7:23 am Post subject: Re: EV-RODENT-SHIELD |
orbeamike wrote: |
If you look at the picture I posted, you notice two square bars coming out of the bumper that goes into the square holes in body. 4 bolts are what attach the 2 pieces together. The same 4 bolts are also used to anchor the hitch receiver if you have that. Unbolt the 4 bolts from underneath the car and couple trim screws along the inner fender and the whole thing comes off. |
Thanks! _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
druuid Samba Member
Joined: April 15, 2021 Posts: 27 Location: West Coast, Canada
Posted: Sat Jul 03, 2021 2:28 am Post subject: Re: EV-RODENT-SHIELD |
orbeamike wrote: |
Ha this is actually a really good idea! Wish I read this before I did mine.
I just did this installation myself for these screens but removed the trim ones and since my model had attached trim to tire flaps it was a bit cumbersome and I had to sort of lay it down.
1995 EVC |
orbeamike Samba Member
Posted: Fri Jul 02, 2021 5:07 pm Post subject: Re: EV-RODENT-SHIELD |
OB Bus Samba Member
Posted: Thu Jul 01, 2021 12:00 pm Post subject: Re: EV-RODENT-SHIELD |
For us who are marginally incompetent when it comes to these things can you share a few details. The 4 bolts that hold the bumper on I’m assuming are obvious. Where are these trim screws that you mentioned? Thank you so much. I have had the screens sitting in the package, in the garage for two years waiting for some reasonably simple way to install them. _________________ Larry in OB
Posted: Wed Jun 30, 2021 1:07 pm Post subject: Re: EV-RODENT-SHIELD |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Tue Jun 29, 2021 5:51 am Post subject: Re: EV-RODENT-SHIELD |
OK- where does that "tunnel" go to-- and is it possible to screen it off or block the path of the air (oh, yes- what does flow in or out there- is it in or is it out?) from somewhere along its route. Stainless steel pot scrubber pads often get used in such places-- at least on Vanagons. I assume that since there are air vent inlets up front, this vent is for outflow. But if we were rodents entering at the under-bumper opening shown, in what spot(s) inside do we emerge into the living space. If we can get to them and stuff some stainless Brillo in, And btw, I have snap-trapped (killed) a number of mice and caught a couple on sticky-traps too, so a "map" of the inlet/outlet's route would be great to see. ?Anyone? |
Posted: Tue Jun 29, 2021 5:50 am Post subject: Re: EV-RODENT-SHIELD |
1961tbird Samba Member
Joined: July 21, 2018 Posts: 291 Location: Halifax, Nova Scotia
Posted: Mon Jun 07, 2021 4:23 pm Post subject: Re: EV-RODENT-SHIELD |
I have a 1995 EVC. Thanks for this information |
TFB777 Samba Member
Posted: Mon Jun 07, 2021 4:00 pm Post subject: Re: EV-RODENT-SHIELD |
Removing the rear bumper on the long-nosed EVs are a bit of a pain. I just removed mine last week in order to Raptor-liner coat the bumpers (and took the opportunity to get those rodent screens installed). While most of the screws on the rear bumper are clearly visible and easily removed, the two hex screws on top which are hidden under the lip of the sheet metal are a real pain! Pull out the rubber hatch gasket and you'll see them. The working space is really tight and gets tighter as you loosen the screws! I wound up having to find two Allen wrenches of the correct size - and then cutting the tips off with a cutting tool. I made one about 1/2" to get the screw started and when it topped out against the body, I switched to my second one which I cut to about 1/4" to complete the extraction. Even when the threads are free, you have to wiggle, jiggle and angle the screws just right with a needle nose plyer in order to get them out! Then you get to do all over again it reverse! A pain, but doable. |
wannabecamper Samba Member
Joined: May 09, 2019 Posts: 211 Location: Sunnyside, US
Posted: Tue Apr 27, 2021 9:01 pm Post subject: Re: EV-RODENT-SHIELD |
I don't know about the long nose vans, but the earlier ones are simple.
- Open the tailgate.
- Remove 2 plastic push pin type anchors on each side at the vertical portion of the bumper.
- Remove 4 plastic caps: Two at the top surface, and two at the bottom surface.
- Unscrew bolts.
The whole bumper piece will slide out. FYI, my 95 has 3 sections; one center, and 2 sides. They come apart after you slide the bumper out. |
steve2sloth Samba Member
Joined: August 25, 2019 Posts: 84 Location: Berkeley, CA
Posted: Tue Apr 27, 2021 4:20 pm Post subject: Re: EV-RODENT-SHIELD |
Ha! I bought this kit too but failed to remove the rear bumper and gave up. As far as I could tell, I have to remove several allen screws and then pull off the weather stripping to access even more allen screws. Then I should be able to remove the cover from the rear bumper. At the time, I was too scared to remove the weather stripping and since then I've installed a cargo box on the hitch. When I find a reason to remove the cargo box again (it's heavy) I'll give it another shot. If you do figure it out, do let us know |
KWard Samba Member
