NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Mon Apr 26, 2021 8:59 pm Post subject: Just stripped the end of my crankshaft |
Title says it all. I started getting a tired 40 horse going for the Spring Oicnic this weekend and really effed things up after getting the end play dialed in.
The 1st 3 threads are pretty flat, the next 2 are iffy and the last 4 look like they've never been threaded into.
Is there anything I can do to salvage this mess? My first thought is to chase the threads and buy a longer chromoly gland nut from SCAT. M28x1.5 Taps aren't horribly expensive on Amazon or Ebay. I haven't come across an affordable thread chaser yet.
4 full threads doesn't sound like much to keep the flywheel in place but I'm hoping I'm wrong. If I get it together and use the clutch gently maybe that would work for a while? Maybe.......
My biggest worry is the flywheel popping off and destroying my new trans. That would really suck balls.
I'll snap a few pics real quick and try to post them up.
Thanks all, NAES _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
NAES Samba Member
Posted: Mon Apr 26, 2021 9:05 pm Post subject: Re: Just stripped the end of my crankshaft |
Box On Wheels
SBS #00 |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Mon Apr 26, 2021 9:27 pm Post subject: Re: Just stripped the end of my crankshaft |
Berg sells and oversize gland nut and can also machine the crank to match if you send them it.
I had a similar issue but your threads look much worse. I just had one thread near the top slighly galled. I would not run it like that, however it might be ok. Clean it really well and take some more pics. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
NAES Samba Member
Posted: Mon Apr 26, 2021 9:42 pm Post subject: Re: Just stripped the end of my crankshaft |
Ok thanks for that info!
I'll clean it out tomorrow and take better pics.
If I have to tear the engine apart then I may as well build a 1776 thats sitting in pieces. The plan was for this motor to be super temporary and a quick install for this coming weekend. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
modok Samba Member
Posted: Mon Apr 26, 2021 9:44 pm Post subject: Re: Just stripped the end of my crankshaft |
From the looks of it....it's not junk yet.
Just need to get enough of the crap out of the threads that the tap starts straight.
Not sure if there is a singular best way to do that but it can be done. If the adrenaline hits hard enough we found a way to do it one way or another.
Poking it to death with a pointy screwdriver and maybe a bit of strategic dremeling, ect.... Wire brushing helps too BTW. |
Wreck Samba Member
modok Samba Member
Posted: Mon Apr 26, 2021 10:28 pm Post subject: Re: Just stripped the end of my crankshaft |
yeah that might help, but thread files aren't one of my favorite tools.
If we get to dream I want one of those an expanding taps where you can get it in behind on the undamaged threads then expand it, and tap outward, but most people don't know they exist and those that do can't afford one.
you can take a bolt with the right pitch pitch, and grind it into a thread massager like that. might help, tho it's no miracle cure. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Apr 27, 2021 3:55 am Post subject: Re: Just stripped the end of my crankshaft |
I’ve been there.
Went to bed that night in the absolute worst mood. But I did manage to salvage it. After inspecting everything it appeared that a full thread peeled off the CB gland nut.
I carefully removed the damage and got an improvised thread chaser started straight, and everything worked out.
Pics halfway down the page
https://www.thesamba.com/vw/forum/viewtopic.php?t=563048&start=160 _________________ modok wrote:
jason Samba Member
Posted: Tue Apr 27, 2021 10:52 am Post subject: Re: Just stripped the end of my crankshaft |
Take an old gland nut and make a thread chaser. Cut a relief in it. I have one of those expanding thread chasers for spark plug holes, works great. |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Tue Apr 27, 2021 5:27 pm Post subject: Re: Just stripped the end of my crankshaft |
modok wrote: |
That does sound dreamy,lol _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 177 Location: Shingletown, CA
Posted: Tue Apr 27, 2021 6:18 pm Post subject: Re: Just stripped the end of my crankshaft |
A friend had this happen to a freshly reassembled engine. He put the entire engine up on the table of a horizontal mill, bored the end of the crank out oversize and tapped it with a larger tap. Then he made a new gland nut to fit.
Of course, he is a machinist with the skills and access to the tools. _________________ Craig ('51 WASP)
Rosie ('63 Double Cab)
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Tue Apr 27, 2021 6:28 pm Post subject: Re: Just stripped the end of my crankshaft |
Doesnt appear to be much engagement of the dowels to the flywheel? |
NAES Samba Member
Posted: Wed Apr 28, 2021 2:39 pm Post subject: Re: Just stripped the end of my crankshaft |
Success!
Took a drive down to DPR where they ran a tap through the threads and cleaned them up. Jose was pretty iffy about how successful the fix would be but there weren't any other quick options.
I got the engine home, got everything set back up and used a chromoly gland nut with loctite. I would rather destroy this eninge if it were to work itself loose as opposed to grenading the trans.
Time to put the rest of the pieces in and send this badboy home.
I'm relieved but not stoked yet. That'll have to wait for the first fire up.
Thank you all for the advice and input. As for the short dowel pins, I don't have an answer for you. Thats what was in there so I left it alone.
Box On Wheels
SBS #00 |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Wed Apr 28, 2021 2:53 pm Post subject: Re: Just stripped the end of my crankshaft |
I wish I could take a drive down to DPR. |
dubman67 Samba Member
Joined: April 10, 2003 Posts: 273 Location: Big Sky Country
Posted: Wed Apr 28, 2021 4:22 pm Post subject: Re: Just stripped the end of my crankshaft |
orwell84 wrote: |
Lol, me too. _________________ 67 Bug
62 Double Cab
[url=https://www.vw-mplate.com/mplate2-54829.png]Click to view image[/URL]
"At 17 got my first Volkswagen...and mastered the life long art of dragin...." Ice Cube |
NAES Samba Member
Posted: Thu Apr 29, 2021 8:35 am Post subject: Re: Just stripped the end of my crankshaft |
It was my first time to DPR. I'm not gonna lie, I was really impressed with their setup just looking inside from the rollup door. I would imagine a walkthrough would be mindblowing. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Thu Apr 29, 2021 3:11 pm Post subject: Re: Just stripped the end of my crankshaft |
If it holds the 235-odd lb-ft, don't worry. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Thu Apr 29, 2021 5:22 pm Post subject: Re: Just stripped the end of my crankshaft |
DPR is who I got my 84mm crank from Great guys.
The stacks of old cases up on the shelf made me sad though. Especially since they don't do cases. Sigh... _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Yep. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
