zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Tue Apr 27, 2021 12:45 pm Post subject: What’s the trick to remove these 6mm Allen bolts? |
I’m replacing the water pump, flushing and installing GoWesty coolant hose end kit.
Got all the bolts on the pump open but the two Allen bolts on the bypass hose from the passenger side to water pump.
I can’t get my Allen key in the top one. The engine pulley is in the way and even the lower one will not budge.
What’s the trick?
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue Apr 27, 2021 12:51 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
Clean any gunk out of the recess in the head so the Allen wrench sits all the way down into it.
Do not use a ball type head. You want the flats to reach all the way down into the socket. A ball type will not get full contact - only on the outside circumference of the "ball"
You can try putting the short leg of the allen wrench into the socket and slip an Box End wrench over the long leg to get some more leverage on the allen wrench. _________________ This free advice is worth exactly what you paid for it.
zoti Samba Member
Posted: Tue Apr 27, 2021 1:00 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
I can’t even get an Allen wrench in the top one. The pulley is in the way. |
4Gears4Tires Samba Member
Posted: Tue Apr 27, 2021 1:03 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
Hah. Yeah those aren't fun. I had the slightest coolant weep there when I put the motor in and figured it needed a little tighten.
I cut down an allen key until it was the shortest it could possibly be, just the depth of the bolt head. Agonizingly little turns will do it. Eventually. _________________ '87 Syncro
Vanagon Nut Samba Member
Posted: Tue Apr 27, 2021 1:04 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
This is a very distant memory but, a "wobble" extension may help. I recall using one during water pump R&R.
Cutting an allen head short then using a box wrench on that, may work.
1988 West DIY 50º ABA
VE7TBN |
rag63 Samba Member
Posted: Tue Apr 27, 2021 1:06 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
A variation of the last post, cut a hex key long enough to fully insert in with a length long enough outside the hex bolt to be gripped by a box end wrench to break it loose.
Then put it in your tool box for special tools.
Cheers,
Dave |
Posted: Tue Apr 27, 2021 1:08 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
zoti wrote: |
Cut it short.
whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Tue Apr 27, 2021 1:10 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
hacksaw
_________________ 84 westie 2.2 w/ digijet, AT |
Posted: Tue Apr 27, 2021 1:11 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
rag63 wrote: |
Cheers,
Dave |
If I have to remove those bolts again I am doing this, but also welding the two together. Or just welding a rod onto my already cut down allen key. I found it too short (the not cut side) to use comfortably in that space. _________________ '87 Syncro
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue Apr 27, 2021 1:15 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
First clean the recess! Next apply valve grinding compound to you your 6mm hex tool. Yes they do make an ultra short 3/8 drive 6mm socket.
BTW it is an m8 bolt with a 6mm hex drive "DIN 911"
IF the bolt is truly frozen a long sharp cold chisel will loosen it when applied to the loosening side. _________________ Schau in das Buch |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
zoti Samba Member
Posted: Tue Apr 27, 2021 1:28 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
How hard is it to remove the main pulley?
I want to also replace the engine mounts and removing the pulley will make that easier plus give me access to the Allen head bolts.
Can it be done in the car? What’s the bolt size? |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Merian Samba Member
Posted: Tue Apr 27, 2021 5:27 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
stubby 6 mm socket - get a good one - you don't want it to round off
or...
cut off a length of a good quality 6mm hex key and put a ratcheting wrench on it
afterwards, hunt down the VW engineer who designed this and kill them _________________ .... |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
zoti Samba Member
Posted: Tue Apr 27, 2021 5:52 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
Merian wrote: |
or...
afterwards, hunt down the VW engineer who designed this and kill them |
I don't understand why the made it with so little space or why they didn't design the main pull with an access hole through it.
also why did they not put a hole in the bottom shields so you can easily take off the coolant drain hole. |
Posted: Tue Apr 27, 2021 5:55 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
The why's of Vanagon design are as numerous as the stars in the sky. _________________ '87 Syncro
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Tue Apr 27, 2021 5:56 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
I have a selection of cut sections of Allen wrenches. The one I use for that bolt is a straight piece about 14 millimeters long. I turn it with a very strong 6 millimeter box end wrench. In my case a Snap-On one. It is hard to find a good 6 millimeter box end wrench. Especially with a 12 point box end. The 12 point box end comes in very handy for restricted access jobs. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Tue Apr 27, 2021 7:36 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
4Gears4Tires wrote: |
The why's of Vanagon design are as numerous as the stars in the sky. |
thanks for the smile .. (I needed that today) _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
