dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Apr 28, 2021 7:12 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
ThIs is the tool of choice. Incredibly tough, just don't abuse it. Mine is nearly 50 years old and still in good condition, always reserved for difficult task.
_________________ Schau in das Buch |
4Gears4Tires Samba Member
Posted: Wed Apr 28, 2021 8:18 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
I have a similar tool. Mine doesn't fit in there. _________________ '87 Syncro
zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Wed Apr 28, 2021 9:29 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
Ok. Nothing works. The bolts are stripping. I need extreme measures.
One stud of the water pump came out with the nut. The other 2 are preventing me from pulling the pump out with the bypass hose.
I need to get this old pump out. |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Wed Apr 28, 2021 10:48 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
here is how i approached the same issue;
clamp J hose from 3/4 head to bleeder ring, clamp pressure tank to bleeder ring hose.
remove both hoses from bleeder ring
jack rear of bus up 22".
lower engine enough to expose pulley, support on cribbing.
WATCH 1/2 hose going to tower and bleeder hose to the thermostat housing!!!! you should be able to lower it without removing them, but you might clamp them and remove just in case.
use impact gun to remove pulley bolt.
use pulley puller to remove pulley.
remove the water pump pulley.
you now have access to the water pump, the cross over pipe, and the high pressure oil sender.
also works if the pulley seal leaks :/
do the needful and slap it all back together.
this takes far less time than you think and gives you good access with normal tools. esp. if you round the allens out. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
zoti Samba Member
Posted: Wed Apr 28, 2021 10:57 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
dabaron wrote: |
this takes far less time than you think and gives you good access with normal tools. esp. if you round the allens out. |
How do you lower the engine without docon eating it from the transmission? |
Posted: Wed Apr 28, 2021 11:01 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
zoti wrote: |
the tranny goes down at an angle with the engine since the tranny front mount is a pivot point.
if you've never dropped the engine before, this might be a tad advanced, but hell, no time like now to learn.
you should invest in a worm gear boat wench to build an engine hoist. best $26.00 i've spent on my Vanagons. _________________ 1991 Vanagon GL Camper
zoti Samba Member
Posted: Wed Apr 28, 2021 11:06 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
dabaron wrote: |
zoti wrote: |
you should invest in a worm gear boat wench to build an engine hoist. best $26.00 i've spent on my Vanagons. |
Gotcha. I need to replace the engine mounts and I have a floor jack so this is probably going to be the next step as I am out of ideas.
Unfortunately, I can’t jack the back of the van at this point. I have it on ramps at the front.
What pulley puller did you use to get the crankshaft pulley off? |
Posted: Wed Apr 28, 2021 11:33 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
zoti wrote: |
https://www.amazon.com/gp/product/B07Z1FKVKS
i'm sure you could back the Vanagon off the ramps, even if you have a friend push it backwards. _________________ 1991 Vanagon GL Camper
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Thu Apr 29, 2021 8:37 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
what works best for me is to use a series of 3/8 drive extensions and go in through the the license plate door where the coolant overflow tank lives, it may sound crazy but it works. as far as the stripped allen bolts I have used a shortened easy-out to grip the ID of the Allen hole in the bolt head.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
zoti Samba Member
Posted: Thu Apr 29, 2021 9:24 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
whip618 wrote: |
Phil |
How do you get to the bolt behind the main pulley? |
lcolon Samba Member
Joined: July 26, 2006 Posts: 57 Location: SF Bay Area
Posted: Thu Apr 29, 2021 10:46 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
I use a bit driver ratchet. I have a few different ratchets in small sizes. You can then use a 6mm "bit" that slots into the ratchet and it fits in behind the pulley. My wife got me a small ratchet set with bits from MAC Tools and I keep it in the van at all times.
You can also buy these off amazon. I would get a high quality one that has many splines. This one is fairly "short" (I have this exact one and use it for a number tight spots on cars) You can get longer ones from pro tool places like MAC that give additional leverage.
https://www.amazon.com/Wera-Square-Drive-Ratchet-T...amp;sr=8-3 _________________ 1984 Vanagon Westfalia - Vanna
1971 VW Beetle |
Posted: Thu Apr 29, 2021 10:51 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
Ah, yes! That's genius. I've had my eye on this set for awhile. I really like Wera tools. This one comes with the rachet and bits. Just ordered it. I'll post pics if it fits.
https://www.amazon.com/Wera-056490-Tool-Check-Ratc...&psc=1 _________________ '87 Syncro
lcolon Samba Member
Posted: Thu Apr 29, 2021 10:54 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
This is the exact one I use for getting back there... It came with a kit with several bits and an extension:
https://www.mactools.com/en-us/Screwdrivers-and-Bi...it-Ratchet
The wera one is nice as well... the Mac one is a little longer for more leverage. _________________ 1984 Vanagon Westfalia - Vanna
1971 VW Beetle |
jberger Samba Member
Posted: Thu Apr 29, 2021 11:32 am Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
https://chapmanmfg.com/products/1000-mity-master-set
This is the ratcheting bit set I use. All ground bit faces.. nice family company too.
For the water pump, I always just commit to pulling the crank pulley. If you don't have the tools to accomplish that I understand but for me it's a must. Pull the Cat and Muffler, heat shield and expansion tank then work in comfort. Really doesn't take that long.
J |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Thu Apr 29, 2021 12:11 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
I use a 6mm Allen 3/8 drive socket. Get a quality brand. Snap-on, Mac, SK, Blackhawk. Possibly European brands. This is one place you cannot afford a failure. The same tool REMOVES CV bolts. Never replaces them tho. I use 12 points. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Thu Apr 29, 2021 12:12 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
I know it seems like the job from hell. After doing it about a dozen times, it's not so bad. _________________ Al Brase
Vanagons:
Merian Samba Member
Posted: Thu Apr 29, 2021 12:51 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
Alan Brase wrote: |
I know it seems like the job from hell. After doing it about a dozen times, it's not so bad. |
Not uncommon - many find they get used to hell after living there for a while...
BTW, Facom makes a nice bit ratchet too. I'm surprised any of them can put down enough torque to budge that heat-welded-rusted-in-place cap screw. _________________ .... |
zoti Samba Member
Posted: Thu Apr 29, 2021 1:20 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
I tried heat with a small torch. Can’t get it hot enough.
I tried a chisel and a hammer. Won’t budge.
Any 6mm tool I manage to get in there just rounds the inside.
So,
Any advise on how to cut the bolts off? I’m tired of those sobs. |
Vanagon Nut Samba Member
Posted: Thu Apr 29, 2021 1:26 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
If you have access, use hand held impact type tool and a reverse bit that would bite into allen head?
As a last resort.....
Drill hole cross wise in bolt head, use a strong pin (stainless?) through that?
1988 West DIY 50º ABA
VE7TBN |
Posted: Thu Apr 29, 2021 1:41 pm Post subject: Re: What’s the trick to remove these 6mm Allen bolts? |
zoti wrote: |
So,
Once the pulley is off you can hammer a 12 point CV bolt bit\socket into the rounded 6mm allen and back it out. It works every time.
J |
