GBodyVillain Samba Member
Posted: Tue Apr 27, 2021 8:34 pm Post subject: Problem trying to get my 74 to run correctly. |
Hey guys, new here. I've had a 74 beetle for some time and never drove it because it just don't seem to run right. I've done some basic things to it to try to get it to run a bit better. The main issue I'm having is it runs and idles sort of okay, then after a little bit if I try to hit the throttle it just sputters and dies. I admit I don't have a ton of experience with these cars.
So one of the things I've done so far was rebuilding the 34PICT-3 carburetor. While rebuilding the carb I noticed the previous owner just put some sort of plug where the idle air jet goes. I took it out and replaced it with an actual idle air jet but it would maybe catch just the start of the thread and would not advance anymore. I looked into the hole and noticed the bore was nowhere near what it needed to be for the idle air jet to fit. Of all the available pictures I could find of this carb, all of them show the idle air jet seated fully into its place. There was a large shoulder inside the hole and I enlarged the bore so the idle jet could fit and got it with as little wiggle room between the jet and the hole as possible and got it as deep as I figured I could then cleaned it out and finished the rebuild. I'm waiting on another carb because I know for a fact I don't know what I was doing with my little modification and want another in case I messed this one up. However, upon installing and running the carburetor I didn't find any issues and the car seemed to run no differently. The bypass and volume adjustments seemed to respond just the same. If there was any difference made, I've not the experience to spot it.
I checked the valve lash and when cold, all the rockers were TIGHT on the tops of the valves. I adjusted them to 6 thou as per my service manual and spent an hour and a half checking and rechecking them to make sure I did them correctly. Car seemed to run a LOT better and was a major improvement. Started more easily and I could save it from dying out would it start to sputter out giving it some throttle.
Next is the distributor and timing. The dist that's on the car is a 113 905 205 AN. Someone installed the gear 180 degrees off so i carefully removed it minding the shims and set it back to where it should be. Took a while but the only timing info I could find on this unit was 5 degrees ATDC while idling between 8-900 rpm. Couldn't get it to start whatsoever. Set static timing to 0 degrees and it ran horribly and for a short while. Static timing once again I set it at 7.5 BTDC and it started right up. Using a timing light I borrowed I tried to adjust the timing to 5 ATDC and it wanted to die right away. I rotated the dist the other way and it kept wanting to run better and better far beyond 7.5 BTDC. However, no matter where I set it, giving it some throttle would cause the motor to hesitate and die out.
I've checked the spark plugs too and gapped them. All of them have spark. I bought new plugs just because and am waiting on those too. I also cannot find any proper vacuum diagrams for this california model 74 beetle. Every single picture I find is different and I can't trust any single diagram or picture. I'm kind of at my wits end here trying to get the car to run right. I don't know anyone that knows these cars well enough to help me sort it out and am hoping someone here can maybe steer me in the right direction. |
kpf Samba Member
Joined: March 01, 2017 Posts: 852 Location: California, US
Posted: Tue Apr 27, 2021 9:41 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
Welcome to the samba!
The AN distributor should have a 4mm ID vacuum hose from the front (towards the front of the car) side of the vacuum canister to the rear of the carburetor. It should also have a 3.2mm ID vacuum hose from the rear of the canister to the left side of the carburetor. I’ll post a picture of the vacuum hoses on my car (1971, but it uses a similar distributor with two vacuum hoses).
You should verify that both sides of your vacuum canister are still working. Use a vacuum pump to make sure they both hold vacuum without leaking. The trouble you’ve had with the timing makes me think that the retard side of your vacuum canister is not working (or not connected correctly).
Other things to verify:
- Is the point gap (dwell) set correctly?
- Is the condenser on your distributor healthy?
- Are the spark plug wires healthy?
Good luck! _________________ 1971 Super Beetle |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Apr 27, 2021 9:49 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
After fifty years you need to verify that you are getting vacuum advance and retard from that canister. Failure is part of their life cycle. Once you determine if you have both, only one or none we can help you time your spark correctly. The mechanical advance can also create problems with being sticky on advance or returning to idle timing. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Thu Apr 29, 2021 4:58 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
The points on the dist have been replaced a couple years ago and not used so still relatively new. I reset the points as per the service manual I have. I have tested the condenser and it seems to be doing good. Tested the plug wires and they look old but test well. I ordered another set just to have that covered. I tested the vacuum on the dist and the retard side is fine. Advance side however leaks a ton. When I have used a timing light and gave more throttle, it would advance at what seemed a consistent rate with which I was giving gas. I'm having trouble finding information or even parts on this distributor. Any of you guys know a source I can get parts from for this dist? Is it even possible to replace the vacuum canister? If I need another dist entirely, what would you guys recommend? I've read the 009 is pretty common however has some issues being centrifugal advance. I was looking at the pertonix SVDA #186504 if I wanted to go with something a bit more modern. Thanks for the reply guys. |
kpf Samba Member
Posted: Thu Apr 29, 2021 8:23 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
I’ve had better luck with restored original parts than aftermarket. One source of original parts is vwnos.com, or check the classified section here. _________________ 1971 Super Beetle |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Thu Apr 29, 2021 10:16 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
I just read through your symptoms and think you got a vacuum leak. Have you retorqued the carb flange nuts? End casting nuts? Then, check the throttle shaft for excessive play. Next up take a good look at the manifold boots. If everything checks out visually, move onto a functional test of the system. You need to check for any vacuum leaks. This is a big one, on these cars. Let’s hear what you find! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun May 16, 2021 5:00 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
Got another vacuum canister from another user here and now the retard side of the canister no longer leaks. I checked the manifold boots and they're still good. I ran the car again and tried to set it at 5 degrees ATD and this time it woudl stay there but just ran absolutely horribly. I checked everywhere I can think of for vacuum leaks and the only place I could find any sort of leak was on the rigth side of the carb throttle shaft when I sprayed a bit of starter fluid on it. I ended up putting an o ring there and crushing it enough to get the leak to stop temporarily then ran the car again. Didn't have any effect that I coudl detect on how the engine ran. I inspected that side where the throttle shaft goes and it looks like it has already been bushed before. |
Posted: Sun May 16, 2021 6:41 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
Also I did retorque the carb flange nuts. Can't reach the end casting nuts with any of the tools I have, just barely tight enough to prevent me from getting onto the nuts much less turn them at all. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Sun May 16, 2021 6:46 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
GBodyVillain wrote: |
S-shaped 13mm box wrenches are available, even at Harbor Freight. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
mouser98 Samba Member
Joined: April 12, 2012 Posts: 300 Location: Lugoff, SC
Posted: Mon May 17, 2021 1:57 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
The main issue I'm having is it runs and idles sort of okay, then after a little bit if I try to hit the throttle it just sputters and dies. |
I was having the same issues, and in my case, it was caused by a bad fuel pump. I noticed my oil level was high, and when I let some of it out, I noticed it smelled like gas. It didn't immediately occur to me what this likely meant, but when reading though some other threads it was brought up that if the fuel pump diaphragm is cracked, it will let gasoline into the crankcase. I replaced my fuel pump and all of a sudden my engine ran great. |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1462 Location: Westfield, MA.
Posted: Tue May 18, 2021 3:28 am Post subject: Re: Problem trying to get my 74 to run correctly. |
I second check the fuel pump. Also you say the valves were tight...thats not good. It would be a good idea to do a compression test. A burned valve will cause all sorts of idling and run issues |
Posted: Fri Jun 18, 2021 11:43 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
Been a while since an update, been super busy with work. Got around to checking compression and cylinder 3 has a major leak, but it seems to be the spark plug threads. If i move the compression tester hose around I can hear it leaking more. The other three cylinders didnt do this, no leaks at all. So I have someone that can help me get the head off and helicoil the spark plug hole, just gotta drop the motor out. I really hope this issue is THE issue. With all the multitude of issues ive found on this car, unplugged vacuum lines, tight valve lashes and rat chewed spark plug wires amongst some other things, it just impresses me to no end that this car would run at all. Fingers crossed on this.
P.S. the fuel pump is fine, works great. Took it out and inspected and tested it. Seems to be in working order. When I changed the oil I didn't smell any gas at all. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Sun Jun 20, 2021 4:00 pm Post subject: Re: Problem trying to get my 74 to run correctly. |
Once you have your engine out you can check everything outside the engine. These engines are fairly easy to start outside of the car. Just set it up on some blocks and stick some fuel to it.
Check the rubber seals on the manifolds when you put the new head on. There are two (one on each side) of the carburetor. These leaking make it harder to time. _________________ www.vwnos.com [email protected]
