OnTheVanagain Samba Member
Posted: Wed Apr 28, 2021 3:13 pm Post subject: Transmission broke while on the highway |
I’m stuck on what to do next. My local mechanic in Vegas suggest I just order a rebuilt transmission but I don’t know where to get one for a good price. My friend suggest to take it to a transmission spot where he says the Cuban guy who works there can fix transmission. What would you guys do? |
11BC2 Samba Member
Joined: August 27, 2017 Posts: 495 Location: Cool, California
Posted: Wed Apr 28, 2021 3:33 pm Post subject: Re: Transmission broke while on the highway |
Well, where are you right now?
Depending on that, ordering up a rebuilt and having a local shop install it might be the best bet.
And don't go cheap on the rebuilt transmission. |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Wed Apr 28, 2021 3:42 pm Post subject: Re: Transmission broke while on the highway |
That sucks. I've been there. I looked for a shop that works on german sports cars figuring they would have a better idea than some random shop. When I broke down in Indianapolis, I found (randomly on google) a shop that fit that criteria, but the whole shop was out at the track racing that weekend, but the owner referred me to another place called RS Performance that worked on a lot of modified Audis. They ended up being amazingly accommodating to get us back on the road.
If I were in your shoes, I'd see if the Cuban guy can assess and tell you more before I ponied up for a rebuilt (and expedited) replacement. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Apr 28, 2021 3:46 pm Post subject: Re: Transmission broke while on the highway |
Bummer. A few questions:
- Manual or auto?
- What's your budget?
Ballpark $1500+ for "good" rebuilt manual, double that for an auto box...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17117 Location: Retired South Florida
Posted: Wed Apr 28, 2021 4:53 pm Post subject: Re: Transmission broke while on the highway |
There are some unique tools required that a “shop” would likely not have. What’s the symptom? Maybe a CV disconnected or broke. _________________ ☮️ |
Dampcamper Samba Member
Joined: October 07, 2013 Posts: 788 Location: Rainy Portland, Oregon
Posted: Wed Apr 28, 2021 5:05 pm Post subject: Re: Transmission broke while on the highway |
These guys are in Bend, Oregon (Central Oregon, on Hwy 97). I have purchased a few rebuilt transmissions from them and have been very satisfied (and no, they were not all for the same rig!).
https://www.germantransaxle.com/
A "run of the mill transmission shop" will likely not be a good choice to have work done on your transmission. VW Vanagon transmissions are not ordinary, run of the mill transmissions and you don't want to pay somebody to learn on the job.
But as advised above, make sure it really is the transmission and not a busted axle or something simpler/cheaper.
What are the symptoms / what happened just before it failed? And your location is...? |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Wed Apr 28, 2021 5:08 pm Post subject: Re: Transmission broke while on the highway |
I got a rebuild from AZ Transaxle in Phoenix about year ago:
https://aztransaxle.com/transaxles
All went well. I opted for some additions which added to the price but hopefully improve drivability and reliability.
I had a local shop remove my old box which I then packed and shipped. They installed the rebuilt upon return.
I got a paper cut writing the check, otherwise no blood spilled. |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Wed Apr 28, 2021 6:00 pm Post subject: Re: Transmission broke while on the highway |
One of the best!
Dampcamper wrote: |
_________________ '90 Syncro Westy w/GW2.5L |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32588 Location: Reading Pennsylvania
Posted: Wed Apr 28, 2021 7:58 pm Post subject: Re: Transmission broke while on the highway |
The mechanic told me the deferential broke. Would the $3000 dollar automatic transmission gowesty awls be my best bet? |
Posted: Wed Apr 28, 2021 8:10 pm Post subject: Re: Transmission broke while on the highway |
I’m going to go with the one from German transaxle for $2000. Should I get the ring and pinion upgrade since I have the 16 inch gowesty wheels? |
Posted: Wed Apr 28, 2021 8:28 pm Post subject: Re: Transmission broke while on the highway |
Depends on your tire size. Anything above 28" would benefit from a 5.43R&P There are so many options when doing what you're doing. Also depends on what you do with your rig. Talk to Ken and he'll steer you in the right direction.
OnTheVanagain wrote: |
jimf909 Samba Member
Posted: Wed Apr 28, 2021 11:11 pm Post subject: Re: Transmission broke while on the highway |
1 - Ken and Katika at GTA in Bend are wonderful to work with. You've chosen well.
2 - What is the R&P "upgrade"? Is it the CHC 3.73 Super Flier? Something else? "Upgrade" can be a mysterious term. _________________ - Jim
Abscate wrote: |
Posted: Wed Apr 28, 2021 11:14 pm Post subject: Re: Transmission broke while on the highway |
Syncronoid wrote: |
Agreed on Ken. Disagree on the 5.43 since the OP apparently has a slushbox. Regardless, agree on the rec of the 5.43 v the 5.50. _________________ - Jim
Abscate wrote: |
Posted: Thu Apr 29, 2021 12:55 am Post subject: Re: Transmission broke while on the highway |
Thanks for the all the help everyone I’ll update everyone after I get the transmission in |
Posted: Thu Apr 29, 2021 4:38 am Post subject: Re: Transmission broke while on the highway |
How did the differential fail? It’s easy to drop the pan and visually inspect it. They are also pretty heavy duty and I don’t recall seeing one fail under normal use. As I mentioned earlier a more common drive failure is a CV. _________________ ☮️ |
Posted: Sat May 01, 2021 2:24 pm Post subject: Re: Transmission broke while on the highway |
MarkWard wrote: |
How did the differential fail? It’s easy to drop the pan and visually inspect it. They are also pretty heavy duty and I don’t recall seeing one fail under normal use. As I mentioned earlier a more common drive failure is a CV. |
I ended up sending using the AAA tow to get the van to the mechanic so I don’t know. Last time we spoke he said the main bearing was failed. I did the CV joints myself 3 years ago with the help of Steve from this website. |
Posted: Sat May 01, 2021 3:56 pm Post subject: Re: Transmission broke while on the highway |
You haven't said where you are at. Maybe 15 years ago I lost a recently rebuilt final drive and pickup up a used replacement for for peanuts. Been running fine ever since. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Sat May 01, 2021 10:09 pm Post subject: Re: Transmission broke while on the highway |
Hmm. Differential fail. Then main bearing fail. And the OP never gave us any symptoms to help get a second opinion, nor where they are broken down.
Not a very good use of a talented bunch of forum folks. Good choice on the transaxle from Bend, though. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sun May 02, 2021 8:16 am Post subject: Re: Transmission broke while on the highway |
IdahoDoug wrote: |
Not a very good use of a talented bunch of forum folks. Good choice on the transaxle from Bend, though. |
I would be nice to get more information on the failure symptoms. Hard to know what a failed main bearing is in a system that has nothing called a main bearing in it TTBOMK. If it just stops going down the road without making a huge bang or making an ever increasing racket previously then that would point to a CV coming loose from its flange, and I would hate to see someone spring for a transaxle rebuild because of six loose or broken bolts. |
