Holes in engine compartment sheet metal
Dougster43
Dougster43 is offline
PostPosted: Wed Apr 28, 2021 7:53 pm    Post subject: Holes in engine compartment sheet metal Reply with quote
Another question for the Thing crowd:
There are 3 holes (roughly 1/2" diameter) on each side of the sheet metal of the engine compartment floor. I think 2 of them are there to allow for lubrication of the bumper bolts, and the third one sits on a lower section so I'm wondering if it is for drainage?
Anyway - should there be any plugs or rubber drain valves installed in these holes?
Thanks as always for the input.
Doug
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Apr 29, 2021 11:03 am    Post subject: Re: Holes in engine compartment sheet metal Reply with quote
Could some of them possible be 12x1mm Rubber Plugs (N020025)? There are a total of 7 of these on the car, several in the engine compartment. Hope this helps.
Photo link to Thing Shop part number N020025
https://www.thethingshop.com/ShowAdditionalImg.asp?number=N020025
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
wbailey2112
wbailey2112 is offline
PostPosted: Fri Apr 30, 2021 10:41 am    Post subject: Re: Holes in engine compartment sheet metal Reply with quote
Not really sure why the bumper bolts would require lubrication since these shouldn't be moving parts.
On my '74 one of these holes on each side is used as an exit point for the drain hose coming out of the rear side vents.
'74 Thing
'83 Westfalia
