Red Fluid (ATF) Leak
Page: Previous  1, 2
djkeev
djkeev is offline
PostPosted: Sun May 02, 2021 5:13 am    Post subject: Re: Red Fluid (ATF) Leak Reply with quote
Helpful thread on how to properly check the ATF level.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8592393#8592393
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sun May 02, 2021 1:30 pm    Post subject: Re: Red Fluid (ATF) Leak Reply with quote
That is no where near a qt on the floor.
You would have a small stream not an oily spot.
Dave
Ghia
Vanagon
Beetle
thebigben
thebigben is offline
PostPosted: Sun May 02, 2021 6:22 pm    Post subject: Re: Red Fluid (ATF) Leak Reply with quote
only put 12 oz or so in, not a quart. again, stopped once I noticed how fast it was leaking. thanks everyone.
Ben
'85 2WD Westy w/ Peloquin TBD + 2.2 Subi (Kurt Vannegut)
djkeev
djkeev is offline
PostPosted: Mon May 03, 2021 5:01 am    Post subject: Re: Red Fluid (ATF) Leak Reply with quote
Understand but ........ Pour 12 oz of water on your floor, see how big the puddle is.
That is a can of Coke.
Dave
Ghia
Vanagon
Beetle
mikemtnbike
mikemtnbike is offline
PostPosted: Mon May 03, 2021 5:04 am    Post subject: Re: Red Fluid (ATF) Leak Reply with quote
If I read this all correctly, the OP's decided to have it towed to the shop where the work was done.
Good decision, better safe than sorry, my opinion.
2020 GTI SE manual
thebigben
PostPosted: Thu May 13, 2021 7:00 pm    Post subject: Re: Red Fluid (ATF) Leak Reply with quote
It’s been there for two weeks or so now. They said it’s leaking from multiple places — both transmission itself and brand new hoses they installed. Moving really slow, partly because they’re also addressing other post-repair issues like coolant leaks, but hopefully next week I can actually drive this thing again (we’re nearing month 7) Confused
Ben
thebigben
PostPosted: Thu May 20, 2021 10:47 am    Post subject: Re: Red Fluid (ATF) Leak Reply with quote
Finally get my van back tomorrow. The transmission was leaking from the O-ring between the diff/trans, connection to oil cooler, and two other internal seals (fluid was coming out of weep hole).
Transmission got pulled twice. Shocked
Ben
Page: Previous  1, 2
Page 2 of 2
