fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Thu Apr 29, 2021 1:26 pm Post subject: Okrasa 36hp or Big Bore 40hp? |
I have both of these. The Okrasa is just being buttoned up and is still on the stand, but the Big Bore 40hp is installed in my '59 bug and has about 5600 miles on it since the rebuild. I'm afraid I'm going to break the crank in the big bore 40hp as I have a habit of taking off fairly hard from stop signs lol.
For those who have driven/owned both, which is more powerful and which do you like to power your vee-dub with? With my specs (below) which one of my engines will be smoother/more powerful?
My specs are as follows:
Okrasa 36hp:
- WW 77mm P&C kit
- stock 64mm crank w/ new main bearings
- WW .345" lift cam
- Stock, but brand new lifter/pushrods
- AA H-beam rods w/ new rod bearings
- WW dual port Okrasa repro heads
- WW 32pbic dual carb kit with bolt-on linkage
- stock 1:1 rockers on new Hoffman Speedster rocker shafts
- stock exhaust with new 36hp dual tip stock muffler (heat risers blocked off)
Big Bore 40hp:
- 83mm AA P&C kit
- stock rebuilt 1965 square-boss heads
- brand new stock cam and lifters
- stock used pushrods
- CB solid shaft 1.1:1 (1600 style) rockers
- 30pict-1 carb with 127 main and 55 pilot jets
- 1 3/8 (stock size tubing) header/extractor feeding dual quiet pack mufflers with blocked off heat risers |
Braukuche Samba Member
Posted: Thu Apr 29, 2021 7:40 pm Post subject: Re: Okrasa 36hp or Big Bore 40hp? |
36hp is correct for a 59, looks cooler too. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
