Smiths Bugs Samba Member
Joined: November 04, 2020 Posts: 15 Location: Garland
Posted: Fri Apr 30, 2021 8:55 pm Post subject: 66 emergency flasher switch |
I recently got this switch out of a notchback but I figure they are all the same so I figured id put it here. I noticed that the knob is different than the bug ones I have. this one is smooth and long where the others have notches. I was wondering if anyone had any info on if this is a type 3 specific or aftermarket knob? please let me know any info is greatly appreciated thank you!
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sat May 01, 2021 6:11 am Post subject: Re: 66 emergency flasher switch |
It does look unique. Maybe you can have one of the moderators move this to the Type 3 section? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34014 Location: Conejo Valley, CA
Posted: Sat May 01, 2021 1:29 pm Post subject: Re: 66 emergency flasher switch |
The switch has a 111 part number, indicating first usage on a Bug, but that is a non-Bug knob. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sat May 01, 2021 5:59 pm Post subject: Re: 66 emergency flasher switch |
that switch is worth a fortune. Well, the red handle part is. For the switch to work it must be mounted in the dash so it gets a good ground. The S connection is a 'switched' ground. In other words when the handle is pulled out S becomes grounded. Push the handle back in the ground goes away. The K connection. When voltage is applied the light in the handle lights up. Independent of the handle being in or out. I used one for a fog light circuit. The fog lights will only work if the headlights are on and they will cut off whether or not the handle is push in or not.
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat May 01, 2021 6:53 pm Post subject: Re: 66 emergency flasher switch |
My question I guess was more about the knob you see how this one is smooth all the way and the others are not. I don’t know if this was something that only came on something specific or what.
Posted: Sat May 01, 2021 8:33 pm Post subject: Re: 66 emergency flasher switch |
Ah----I now understand the question. But alas-----I have not an answer. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun May 02, 2021 7:36 am Post subject: Re: 66 emergency flasher switch |
Ghia and Beetle knob differences.
Ghia is smooth Beetle is ribbed.
Designed to match thier respective model knobs
https://www.thesamba.com/vw/forum/viewtopic.php?p=6400327
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
