Callookbeetle Samba Member
Posted: Sat May 01, 2021 2:57 am Post subject: Beetle Clutch Cable |
I have done the Adjustment on my Clutch cable on my Beetle and added the washers and tightened it up etc but the Clutch pedal seems to still go very low when engaging Gear.The Cable looks fairly new,any ideas? |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Sat May 01, 2021 4:26 am Post subject: Re: Beetle Clutch Cable |
Worn clutch disc, weak pressure plate. ? _________________ "Albatross"! |
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Sat May 01, 2021 4:28 am Post subject: Re: Beetle Clutch Cable |
I would suggest to first double check the adjustment. I believe the spec is 1/2” to 3/4” clutch pedal free play measured at the top of the pedal pad. _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Sat May 01, 2021 8:10 am Post subject: Re: Beetle Clutch Cable |
Callookbeetle wrote: |
Could be cracked/broken clutch pedal itself (had pedals on both my VWs welded to fix)
Could be bad clutch pedal hook
Could be broken clutch tube mount inside the tunnel (there are three); these also broke on my two VWs. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Sat May 01, 2021 9:53 am Post subject: Re: Beetle Clutch Cable |
I have done the Adjustment on my Clutch cable on my Beetle and added the washers |
Explain the washers; on bowden tube or somewhere else??? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat May 01, 2021 10:05 am Post subject: Re: Beetle Clutch Cable |
Yes the washers are on the Bowden Tube ,I saw it online and the Bowden Tube has a slight bend and even when it's tightening right up the peddle still goes down quite far when engaging Gear |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sat May 01, 2021 10:42 am Post subject: Re: Beetle Clutch Cable |
Pushing the pedal in results in the clutch/gear disengaging, whereas letting the pedal up results in the clutch/gear engaging -- so are you having a problem where the clutch engages only when the pedal is near fully released or is it a problem where the clutch will not disengage until the pedal is near fully depressed? _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue May 04, 2021 2:01 pm Post subject: Re: Beetle Clutch Cable |
It's putting the Gear in whilst driving,the gear goes in fine but I've noticed that the pedal goes near enough to the floor whilst doing so when it didn't previously if that makes sense |
Cusser Samba Member
Posted: Tue May 04, 2021 4:03 pm Post subject: Re: Beetle Clutch Cable |
Bad/stretched cable
Bad bowden tube _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue May 04, 2021 4:10 pm Post subject: Re: Beetle Clutch Cable |
Cusser wrote: |
Bad/stretched cable
Bad bowden tube |
Sadly, I've had every one of these (except weld breakage inside the tunnel) happen to me over the years, so check for all of them! |
Cusser Samba Member
Posted: Tue May 04, 2021 6:26 pm Post subject: Re: Beetle Clutch Cable |
KTPhil wrote: |
Cusser wrote: |
Bad/stretched cable
Bad bowden tube |
I've had all except the bowden tube issue on both my 1970 and my 1971; I've owned them since 1972 and 1976 respectively.
I've experienced just once a broken clutch cable when I've been driving, had just gotten off the freeway in California back in 1979 driving the 1970; but I had a spare cable and wingnut with me, changed it in a mortuary parking lot.
I've not myself experienced an accelerator cable break on mine while driving, but an old girlfriend did, and so did Mrs. Cusser. Mrs. Cusser experienced a clutch cable breaking in the 1971. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
