74 standard - loose steering, suspension rebuilding
cptcrusty1
cptcrusty1 is offline
PostPosted: Sat May 01, 2021 5:46 am    Post subject: 74 standard - loose steering, suspension rebuilding Reply with quote
Hi all;
I've been slowly working through my 74's front suspension. I've had 2 other beetles, both before TheSamba, or, wide internet usage so it's been a while since I"ve been in the practice.
My steering has a deadspot. I'm replacing parts that are obviously worn (both lower bj's, will get to the uppers soon. both outer Tie Rods are done. But I still have an dead spot.
I've read about the steering boxes being notoriously bad. My friend says there is a "nut" you can tighten, kind of like a grub screw, but that it's only temporary. I"d like to remove the deadspot if possible.
Is there a thread that refers to this? I haven't found it yet. Thanks in advance.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat May 01, 2021 6:09 am    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
I assume you have a Standard and not a Super.
This might help:
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat May 01, 2021 11:46 am    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
Where in the travel is the ďdead spotĒ? It might just be the center point.
DO NOT OVER TIGHTEN THE ADJUSTMENT STUD!
Jimbo
nshaddox wrote:
Plus I tend to prefer these impossible projects that take way too much time. Thereís no thrill in easy projects. Challenges are fun.
67rustavenger wrote:
Starbucket
Starbucket is offline
PostPosted: Sat May 01, 2021 1:23 pm    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
There are two adjustments one is adjusted from the front of steering box and the other one is on top.
sjbartnik
sjbartnik is offline
PostPosted: Sat May 01, 2021 1:59 pm    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
And if you do it wrong you can destroy your steering box real quick.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Starbucket
PostPosted: Sat May 01, 2021 2:17 pm    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
Covered on Front Axle 21 - 23 of the Bentley manual Don't have time to copy it for you but maybe someone will. I'll check back tomorrow.
cptcrusty1
PostPosted: Sun May 02, 2021 10:44 am    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
Center is the dead spot. A friend said it had to be adjusted frequently.
Anything on the adjuster for the front of the steering box?
VW_Jimbo is offline
PostPosted: Sun May 02, 2021 11:02 am    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
If it needed attention often, then it is probably toast. They do not require any attention, really. They are very stout units.
The front nut, itís a big one, with the locking nut is for removing the free play from the worm gear. The other one on top is for the roller gear.
Read through this thread for the info needed. Very nice write up!
https://www.thesamba.com/vw/forum/viewtopic.php?t=660446
Jimbo
Starbucket
PostPosted: Sun May 02, 2021 12:52 pm    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
Hope you can read them.
sjbartnik
PostPosted: Mon May 03, 2021 5:26 pm    Post subject: Re: 74 standard - loose steering, suspension rebuilding Reply with quote
Before adjusting the steering box the key is to remove all other sources of play/slop in the front end. Wheel bearings, ball joints, tie rod ends, steering box mounting hardware, etc.
Once all that is good you can proceed to adjust the steering box.
In most cases you shouldnít have to mess with the adjustment at the giant nut. The one that needs semi-regular checking and adjustment is the one at the top of the box with the 17mm lock nut.
Front wheels need to be off the ground, steering wheel turned 90 degrees to either side from center.
Loosen lock nut, unscrew the adjusting screw a bit. The bottom end of the adjusting screw, which you canít see, is a bearing surface. When adjusted properly, it just makes contact with the top of the roller shaft inside the box to keep the roller shaft from moving up and down in the box (thus causing play/slop in the steering).
So you tighten the adjusting screw very gently until you just feel it contact the top of the roller. Iím talking just contact. You donít tighten it further, tighter is not better. Then you tighten the lock nut.
Again, do not over tighten the adjuster. For serious. New steering boxes are trash so try to make your old one last.
2000 Kawasaki W650
