DeathBySnuSnu Samba Member
Posted: Sat May 01, 2021 10:18 am Post subject: Suspension and Handling |
Several questions.....hoping for some experience.
I a building a kit car and as per my usual self.....things get a bit out of hand.
So now it is a full tube chassis, close to beetle wheel base length, v6 mid engine (all aluminum not very heavy).
901 side shifter 5 speed.
Cut some more castor in the head (pie cut)
Drop spindles.
Ball joint front.
19mm sway bar
Bent the top arms so with the extra offset bushings I can go +1 to -2 on front camber.
IRS rear.
Reinforced arms
Poly bushing
28mm spring (short swing type)
NO rear sway bar (yet)
-2 rear camber (trying to tweak this down to a -1)
So here are the question.
I plan on splitting at least one of the front spring packs and doing a double adjuster.
Which beam ? Top or bottom?
When adjusting a different pre load top vs bottom.....
Which is the primary load?
On the rear....
I have double spring plates.....are the adjustable plates robust enough for a 200hp sport about (not a drag racer)? _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sat May 01, 2021 10:29 am Post subject: Re: Suspension and Handling |
DeathBySnuSnu wrote: |
Top. You want to have the spindles to press on the ball joint, not hang in it.
On the rear....
Couldnt say. I have never used those
_________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Sat May 01, 2021 10:50 am Post subject: Re: Suspension and Handling |
Thanks.
Yeah I did think of the top ball joint load.
I guess the double adjuster/split spring can be the top also.
I do not know if I actually need the rear adjustable plates or not. Original plan was the early double plates (and I have them already). _________________
modok wrote: |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sun May 02, 2021 5:01 am Post subject: Re: Suspension and Handling |
It has been my impression that due to the roll steer and bump steer problems built into the VW front beam, they handle best when they are sprung stiff. In fact I have heard guys express the opinion that the ONLY reason they work at all in autocross is because they are stiff. That I believe is why VW and Porsche abandoned them and went to struts on the front. The trailing arm system does go through a number of complex angle changes in it's travel.
I have often thought that a center mounted steering box and equal length tie rods would make a big improvement. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
modok Samba Member
Posted: Sun May 02, 2021 1:42 pm Post subject: Re: Suspension and Handling |
That bump steer is mostly in their imagination or of their own doing from not positioning the pitman arm correctly.
it's not a great system.... all parts have a lot of of flex for how heavy it is, but there is not much bump steer and no speed wobble. Grass is always greener |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6032 Location: CONGERS, N.Y.
Posted: Mon May 03, 2021 4:23 pm Post subject: Re: Suspension and Handling |
First I agree with Modok, bug steering is archaic, Ok but privative.
Kit car, most likely lighter then a bug. I am going to save you some money and maybe your life.
Have my bug since 1988, here is what I did and got rid of.
Stiff Gas shocks, did work lower the bug and they raised it, ride was bad. Went for stock shocks.
Rear Sway bar, it is ok for handling but really not that much better and puts a lot of stress on the car when making turns.
My car now has HD front sway bar, 2 1/2" dropped front spindles. 4 wheel disc brakes ( with emergency brake ).
195 60 15 rear tires and 195 50 front racing tires, they dropped the front another inch.
My main point. My bug is heavier then your kit car. I have a 914 2.0 engine.
from a 914 that had a top speed of 127 mph.
Tried that and got from 60 to 100 in seconds but my steering got real light and I felt I was going to lose control of the car.
Forget the front torsion bars.
Below is front drop and rear is stock.
_________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
spencerfvee Samba Member
Posted: Mon May 03, 2021 4:41 pm Post subject: Re: Suspension and Handling |
nextgen wrote: |
...............................................................................................................i love the looks of your bumpers . those are bad ass. i all so like the looks of your bug . its got a real clean look to it . great job spencerfvee |
Posted: Tue May 04, 2021 4:51 pm Post subject: Re: Suspension and Handling |
nextgen wrote: |
Below is front drop and rear is stock. |
I would like for you to expound on your warning/advice.
I do not understand what you are recommending.
I have had VW's since 1975.
Around 1978 my beetle, swing axle not significant lowered in rear, cut front beam lowered as far as the ball joints would allow.
I learned real quick that I had taken the castor out of the front by going nose down. I welded some spacer bars in the lower beam socket and put longer bolts in (I was 17 and knew nothing about castor shims that fit right). But it drove better.
I was radar clocked at 135mph. I could not sustain that speed.....the down force on the front from being nose down had the front so hard bottomed out that the tires were rolling smoke from rubbing the fenders. It was soooooper stiff at that speed.....but I think that was from tire rub.
The kit car.....I dunno how much if any lighter it will be on the front......it is mid engine so that probably moves some weight forward. It is 4 wheel disc with park brake. I have added a lot of castor.
In all reality......I m old.....it probably will never go fast.....I might try some parking lot racing but that is low speed stuff.
My motorcycle has more hp than the car will...., _________________
modok wrote: |
Posted: Tue May 04, 2021 6:43 pm Post subject: Re: Suspension and Handling |
Did not know you were as old as I am and the experience. Mine started in 1967 when I raced MGA Roadsters. Photo is that year in the Bronx I was 18 in the photo, do the math. BTY the women shown after a snow storm became my wife.
The only things I was not recommending was screwing with the front beam.
Hey you did it before. Also the The rear sway bar but seeing it is mid engine, it is up to you.
Wreck Samba Member
Posted: Wed May 05, 2021 12:34 am Post subject: Re: Suspension and Handling |
back in the late 80's I had a 68 bug which I converted to IRS , it had a 3.88 box , 2lt upright type 4 . front and rear sway bars and good oil shocks .lowered a little front and rear with no rake. On one or two occasions I had the speedo needle firmly on the wrong side of the stop !
I then had a moment brain fade and bought a Eureka /Sterling kit car and rebuilt it swapping the pan/running gear with the bug . 265/50r14's on the rear and 245/50r14's on the front . It could do 180km in 3rd gear and I did that often.
modok Samba Member
Posted: Wed May 05, 2021 4:41 am Post subject: Re: Suspension and Handling |
Not sure what he was rambling about but I agree as far as...If there was any wild idea that makes it all work better we've all been looking but never found it. For instance...
Lets space the front wheels out and run a lot of caster and maybe that would help low speed understeer?..... and it could in theory, but at least IMo, just doesen't feel right.
I rather keep the scrub radius to a minimum so the flex in the arms just causes the wheel to tilt instead of flopping around up and down.
Front springs aren't adjustable, but it may end up about the same front end weight as a bug anyway, so that'll work itself out. IMO the main reason the front torsion bars were at different angles was to get over the bump stop, on the early beam.... but then why is it also like that on ball joint beam? Maybe just to make it easier to assemble the ball joints into the knuckle. If there is any other functional reason I never found what it is. Both arms are pushing down unless you are flying. Kinda like the three shims. Must be the magic number, but it isn't really. I've set them at both the same angle, never found any difference. Tires make the most difference. Always looking for a REAL tire small enough for the front end, which seems to be determined by whatever the smallest new car happens to be lately. |
Posted: Wed May 05, 2021 5:17 am Post subject: Re: Suspension and Handling |
The old beam front works amazingly well......for what it is.
One thing to consider.....I am trying to make a psuedo euro racer.....it will be a lot of yester-tech.
Not running a huge tire.....but not small.....205's on front and 215's on back. Front is 23.5 tall. The disc brake drop spindles pushed the wheels out.....but I have heavy offset wheels. With the offset camber bushings, and bending the top arms.....I got the scrub back within reason and the camber adjustable from +1 to -2
I pie cut 6 added degrees in a head. That might be a bit much but not to sure....can always tweek from there with shims.
I am splitting one of the springs.....I will lose an inch of spring each side which will stiffen it up a bit. I have a basic 3/4 front sway bar. The back has 28mm torsion bars. I do not have any rear sway as of yet.....I was hoping the stiff bars would take care of that. Of course you know center of gravity of the engine is higher than the flat four.
The engine is not all that powerful...... little 2.5L around 200hp....but is an 8000rpm screamer. _________________
modok wrote: |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat May 08, 2021 9:43 am Post subject: Re: Suspension and Handling |
I was working on making a aluminum front beam for a saltflat car that I never went to far with, it was going to have a lot of castor adjustment I wonder if you could do something for a handling car for Auto X or road racing.
I also have been thinking about making a pitman arm for the pass side of the beam and using two equal length tie rods.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
