Russ1967 Samba Member
Posted: Sat May 01, 2021 4:54 pm Post subject: 6v Hard Start Relay- What Gauge Wire? |
What gauge wiring should be used for a hard start relay on a 6v Beetle?
10ga?
12ga?
Thanks. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sat May 01, 2021 5:01 pm Post subject: Re: 6v Hard Start Relay- What Gauge Wire? |
The relay goes between the starter solenoid and the ignition switch, so 16ga is fine. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat May 01, 2021 5:32 pm Post subject: Re: 6v Hard Start Relay- What Gauge Wire? |
Got it.
Thanks! |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sat May 01, 2021 5:47 pm Post subject: Re: 6v Hard Start Relay- What Gauge Wire? |
yes 16 ga. can be used from the ignition switch to one side of the coil of the 'hard start' relay. The other side of the 'hard start' relay connection should be 16 ga also. The battery connection and the starter solenoid connection on the 'hard start' relay should be at least 12 ga. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Sat May 01, 2021 6:01 pm Post subject: Re: 6v Hard Start Relay- What Gauge Wire? |
Point taken.
Thank you! |
