Master Cylinder
Rhino1966
Rhino1966 is offline
PostPosted: Sun May 02, 2021 1:48 pm    Post subject: Master Cylinder Reply with quote
I have a 69 Type 3 Squareback and replacing the Brake Master Cylinder. The old one is a THREE circuit two prong and all replacements are two circuit. What are the three circuits for and can I replace it with a two circuit?
Mike Fisher
Mike Fisher is offline
PostPosted: Sun May 02, 2021 6:48 pm    Post subject: Re: Master Cylinder Reply with quote
German ATE master cylinder fit fine on my '69 square. Not the cheapest, but the best!
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Rhino1966
PostPosted: Mon May 03, 2021 2:36 am    Post subject: Re: Master Cylinder Reply with quote
I have not found a three circuit replacement. What are the three circuits for and can I replace with a two circuit?
Bobnotch
Bobnotch is offline
PostPosted: Mon May 03, 2021 5:52 am    Post subject: Re: Master Cylinder Reply with quote
Yes. In fact VW replaced it with the 71 and later style dual circuit version themselves. They obsoleted the 3 chamber set up at the same time (why you can't find one). You'll need to switch the brake light switches to the 3 wire units, and alter the wiring as shown in the brown Bentley to keep the dash warning light function. If you're not worried about it, you can use your 2 wire switches. Keep in mind you might have to replace your left front hard line depending on the port configuration of your new master cylinder, with a longer line. Most of us have already done this.
I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
