S4VAGE Samba Member
Posted: Mon May 03, 2021 10:45 am Post subject: Modify 944 wheel to incorporate 911 spline? |
I have a pristine 944 three spoke sport steering wheel that I had used in a Vanagon for many years. My 911 has a very sad aftermarket wheel in it, but the guts have the spline/hub parts behind it. I am wondering if there is a way to swap the 911 spline into my 944 wheel, or if it is worth the trouble. |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Wed May 12, 2021 12:22 pm Post subject: Re: Modify 944 wheel to incorporate 911 spline? |
Not that I have seen.
I know you can take the adaptor off of a 944/3 spoke wheel.
I have done it.
I have also modified them to fit other cars (Porsche wheel in my 73 beetle).
As far as fitting another adaptor, you might have to drill/tap some holes and trim things.
You can make anything work with enough machine work.
I believe the splines are all the same. Just the offsets and turn signal cancel cam can be different. |
S4VAGE Samba Member
Posted: Thu May 20, 2021 9:05 am Post subject: Re: Modify 944 wheel to incorporate 911 spline? |
Thanks Tom, I have decided to sell my 944 wheel to help fund a proper 911 one. My 944 is super nice so it feels criminal to drill/cut on it. |
Joined: December 28, 2016 Posts: 280 Location: atlanta ga
Posted: Fri Jul 02, 2021 9:03 am Post subject: Re: Modify 944 wheel to incorporate 911 spline? |
break the hub rivets switch the hub and use screws to bolt the wheel to the 911 hub |
