dubman67 Samba Member
Joined: April 10, 2003 Posts: 273 Location: Big Sky Country
Posted: Mon May 03, 2021 1:30 pm Post subject: Berg full flow oil pump, tricks to getting one out of engine. |
So, during the cam break in of my rebuilt 2021, I noticed I have an oil leak between my oil pump and case. The oil pump is a Berg full flow with the machined oring.
How do you get it out? With the pressure port blocked off, you can't get both ends of the puller in the pump. I tried doing it with the the one end in the suction side, but it just bends the piece on the puller.
What's the trick? _________________ 67 Bug
62 Double Cab
[url=https://www.vw-mplate.com/mplate2-54829.png]Click to view image[/URL]
"At 17 got my first Volkswagen...and mastered the life long art of dragin...." Ice Cube |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Mon May 03, 2021 1:32 pm Post subject: Re: Berg full flow oil pump, tricks to getting one out of engine. |
Did you loosen the M8 nuts above and below the pump? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon May 03, 2021 1:42 pm Post subject: Re: Berg full flow oil pump, tricks to getting one out of engine. |
Glenn wrote: |
Did you loosen the M8 nuts above and below the pump? |
Is that what you're supposed to do? I thought about it, but was afraid I'd have a leak at the case halves. _________________ 67 Bug
62 Double Cab
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Mon May 03, 2021 1:45 pm Post subject: Re: Berg full flow oil pump, tricks to getting one out of engine. |
Loosen the bolts Glenn mentioned, then remove the drive gear and the 4 pump studs, then you can twist the pump to break the gasket seal. You can modify the puller too so it only locks into the feed port _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Sat May 08, 2021 3:50 pm Post subject: Re: Berg full flow oil pump, tricks to getting one out of engine. |
Thanks Glenn. Worked like a charm. Now leak free. _________________ 67 Bug
62 Double Cab
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Sat May 08, 2021 8:29 pm Post subject: Re: Berg full flow oil pump, tricks to getting one out of engine. |
Pic or more info? |
Teeroy Samba Member
Posted: Sun May 09, 2021 7:57 pm Post subject: Re: Berg full flow oil pump, tricks to getting one out of engine. |
I have an extra puller that I cut the small (outlet galley) leg off, so it looks like an L not a T. You use the larger end in the feed galley port only, hold a little pressure on it until the nut is tight so it stays put, then keep tightening as normal to pull the pump _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
