kirk knighton Samba Member
Joined: January 23, 2005 Posts: 282 Location: Seattle
Posted: Mon May 03, 2021 2:06 pm Post subject: Fuel Filter on a 1985 Cabriolet |
I think mine needs changing. Question is - where is it? Is it in the fuel tank? A difficult job to replace? |
timvw7476 Samba Member
Posted: Tue May 04, 2021 12:06 am Post subject: Re: Fuel Filter on a 1985 Cabriolet |
is it still CIS Bosch injection?
That filter is under the car, near the passenger side tire.
One 10mm bolt clamps it in place, and an open-end wrench is needed to hold the filter can in place as you undo two banjo bolts to free it. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Tue May 04, 2021 7:02 am Post subject: Re: Fuel Filter on a 1985 Cabriolet |
I thought they were closer to the air filter. That may have only been with the Rabbits. Worth opening the hood to see if it's there. |
Posted: Tue May 04, 2021 9:14 am Post subject: Re: Fuel Filter on a 1985 Cabriolet |
timvw7476 wrote: |
Front passenger tire or rear? |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Tue May 04, 2021 9:32 am Post subject: Re: Fuel Filter on a 1985 Cabriolet |
It should be tucked between the fuel distributor/air box & the strut tower on the driver side. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
mk13nb Samba Member
Joined: November 17, 2016 Posts: 13 Location: Winnebago, IL
Posted: Tue May 04, 2021 9:49 am Post subject: Re: Fuel Filter on a 1985 Cabriolet |
TDCTDI wrote: |
It should be tucked between the fuel distributor/air box & the strut tower on the driver side. |
Yep, put a towel on your fender so you don't bash the paint when the wrench finally breaks free. |
Posted: Tue May 04, 2021 7:54 pm Post subject: Re: Fuel Filter on a 1985 Cabriolet |
TDCTDI wrote: |
Yes I think that's it! A big silver cylinder thing, with a hose coming out of either end.
Question is: will gas spurt all over when I turn that bolt? Or is it only pressurized when the engine is running or the key turned on?? |
