coolairX2 Samba Member
Posted: Mon May 03, 2021 6:19 pm Post subject: Sourcing rivets for a split window Pope's nose |
I have a spare split window Popes nose that has the rivets removed and I would like to source rivets to attach the inner structure to the skin.
Can a direct replacement or close facsimile be used? I would like to make this whole to combine with my deck lid. |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Tue May 04, 2021 12:18 pm Post subject: Re: Sourcing rivets for a split window Pope's nose |
Nice thanks for the tip |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Wed May 05, 2021 1:47 pm Post subject: Re: Sourcing rivets for a split window Pope's nose |
I might have some brass brads that I have used as rivets before. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Fri May 07, 2021 5:23 pm Post subject: Re: Sourcing rivets for a split window Pope's nose |
Were the originals brass or aluminum ? If I cannot source any I may checkout what you have .
Thanks |
Posted: Fri May 07, 2021 6:50 pm Post subject: Re: Sourcing rivets for a split window Pope's nose |
Pretty sure they were aluminum. You can probably find aluminum ones. I have made many a rivet with nail stock, sometimes spinning it in the drill press and shaping the head with a file or Dremel. _________________ John Henry
'57 Deluxe
'56 Single Cab |
rag63 Samba Member
Posted: Sun May 16, 2021 9:41 am Post subject: Re: Sourcing rivets for a split window Pope's nose |
Have you looked into rivets used for aircraft?
AN470 are domed
AN426 are countersunk.
They are SAE sized, no metric dimensions.
You can get them in soft aluminum. Strong enough to probably do what you need. Stronger alloys are available too.
Cheers,
Dave |
