Dome Light Fuse
tunnvar
tunnvar is offline
PostPosted: Tue May 04, 2021 9:11 am    Post subject: Dome Light Fuse Reply with quote
I think I have blown a fuse trying to replace the dome light with an LED light. I can't seem to locate the fuse. Does anybody know where it is? Also, was an LED light a bad idea? Cheers!
1970, Deluxe, 1600cc, Type 1 Dual Port
[url=http://www.vw-mplate.com/mplate2-35638.png]Click to view image[/URL]
busdaddy
busdaddy is online now
PostPosted: Tue May 04, 2021 10:19 am    Post subject: Re: Dome Light Fuse Reply with quote
Слава Україні!
tunnvar
tunnvar is offline
PostPosted: Tue May 04, 2021 10:37 am    Post subject: Re: Dome Light Fuse Reply with quote
Lovely, thank you sir! Need to save that image.
Wildthings
Wildthings is offline
PostPosted: Wed May 05, 2021 2:46 am    Post subject: Re: Dome Light Fuse Reply with quote
Helps to learn how to read the electrical schematic for your year. Getting a copy of the diaphragm enlarged at a print shop and then laminated isn't a bad idea. This drawing can be found in the Technical Section which shows up towards the top right of every Samba page. Note that the fuse box is reversed.
tunnvar
tunnvar is offline
PostPosted: Wed May 05, 2021 8:21 am    Post subject: Re: Dome Light Fuse Reply with quote
Excellent, will do, thank you both!
bsairhead
bsairhead is offline
PostPosted: Wed May 05, 2021 8:35 am    Post subject: Re: Dome Light Fuse Reply with quote
Your bi-line makes no sense to me.
tunnvar
tunnvar is offline
PostPosted: Wed May 05, 2021 12:01 pm    Post subject: Re: Dome Light Fuse Reply with quote
Let me know what a bi-line is and I'll try help you out. Very Happy
Mberglo
Mberglo is offline
PostPosted: Wed May 05, 2021 12:45 pm    Post subject: Re: Dome Light Fuse Reply with quote
I think he means your signature line. A 1970 1600cc would be a Type 1.
Mberglo
Mberglo is offline
PostPosted: Wed May 05, 2021 12:48 pm    Post subject: Re: Dome Light Fuse Reply with quote
Did the fuse fix your light? Im curious how that LED bulb works. LEDs have a polarity, and I would imagine its possible to put a bullet type bulb in backwards.
tunnvar
tunnvar is offline
PostPosted: Wed May 05, 2021 2:27 pm    Post subject: Re: Dome Light Fuse Reply with quote
Ha. I did that line several years ago trying to sound like I knew what I was talking about. Never even looked at it since.
Yes, the #11 fuse had blown. I have power to the dome light but the new LED ceiling light is being a bit temperamental. Works one minute and not the next. The door feature doesn't seem to work at all I can't seem to figure it out. It's a cheap thing I picked up off amazon so not too worried.
bsairhead
PostPosted: Wed May 05, 2021 3:30 pm    Post subject: Re: Dome Light Fuse Reply with quote
That is what I was talking about. If you have a type 4 motor in a 70; Very cool, if you have a type 4 motor that is 1600cc different, if you have a type 4 motor that is not duel port I want one. I see you changed your signature line to type 1. I was hoping you had a type 4 1600cc motor. I think that would be cool.
tunnvar
tunnvar is offline
PostPosted: Wed May 05, 2021 3:50 pm    Post subject: Re: Dome Light Fuse Reply with quote
Mberglo set me straight!
